First track day experience
Unfortunately for me, my day was cut short when I slid off the track and damaged the pan hard bar and the driver rear axle. The axle shaft flange bent .068" out, so one side of the flange moves away from the caliper mounting bracket than the other( imagine 12 o'clock measuring .068" out further than 6 o'clock). The rotor is ok and the wheel is still straight, I checked those things out already.
Question- can the axle shaft flange be bent back in place? If not, do i need to find another LS1 car at a junk yard or do all f body's in that year range have the same axle shafts?
The other question I have is if all 1998-2002 camaros and firebirds had a pan hard bar? And then, is the same pan hard bar used for all of them and is that true for the Firehawk's.
I was amazed by how well my Firehawk handled the corners and twists. And the power the LS1 delivered out of the turns was great! Obviously, I didn't learn enough, soon enough because I spun.
Safety is certainly important, but as long as you observe all of the rules, take care of your equipment and drive within yourself, you will be fine. I've been running track days (in a convertible) for 6 years now and have only seen one person hurt - a first-timer who walked away with a few scratches and bruises. The worst I've suffered is a little sunburn.
You spun most likely because you let out of the gas.
Rule#1, the gas pedal is your friend.
