Which rear LCA's?
I mention this because I can not run heim joints in ESP, and I'm contemplating replacing bushings as time goes on since they are still original with 70K mi.
I'm sure things still slightly move side to side in a Watts Link setup due to things flexing, but I would say DRASTICALLY less then a PHB setup. I would be curious to know the general amount of movement side to side of the axle during a typical autocross with a PHB setup.
See example 1: My car on a ~70sec course on concrete with 275/40/17 V710's.
https://www.youtube.com/watch?v=xgje6dnQGrA
And I would make sure they are adjustable. I wouldn't replace any stock component with something that couldn't be adjusted.
With that said, my goals are that my car will be mostly for street. I may take it to a drag strip for ***** and giggles or I may even try taking it to a track. I will favor handling more than straight line performance. I am also keeping in the back of my mind that I may need to get an aftermarket rear end. If I do, I have settled on the MWC Fab 9 as it is a bolt on replacement for the stock rear end (if I researched correctly). I am torn between getting the double adjustable rear LCAs from either MWC HEIM ends or UMI Roto-joints. Since it has been a year, how are the HEIM ends doing?
