Road Racing Road Course | Autocross
Ls 240
Old Mar 26, 2018 | 03:05 PM
Precisionfab's Avatar
Default Ls 240
I have been building hot rods and drag cars for a long time, but after going to Road Atlanta last fall I'm starting something different, at least for me. I have an s13 hatch that I have completely gutted. All that remains is roof, quarters, windshield, rocker panels, and a small section of floor. I plan to build an entire tube frame, front and rear suspension, cage and use as much fiberglass panel as I can. I want to come in at 2000 to 2100 lbs with an aluminum LS and TKO 6 speed. I plan to stuff as much rubber as possible (295/40/18) on the rear and slightly smaller on the front. I plan to be able to do anything I want with it, track days, autocross, drag race, etc. I'm thinking 4 link rear and A arm front. Which brings me to my question. Since I want to keep all 4 tires on the pavement in a turn, should the front or rear be a little looser? Which end should the stiffer sway (anti roll) bar be on? Thanks! Steve
Old Mar 26, 2018 | 03:46 PM
STANG KILLA SS 2's Avatar
bigger bar always goes up front.
i do want a LS 240. for either track car or rally.
Old Mar 26, 2018 | 05:28 PM
dojob's Avatar
Video series of build and everything needed
Old Mar 26, 2018 | 11:17 PM
gnx7's Avatar
If you really want to go fast.... you should focus on aerodynamics as well. Lots of power is worthless without it.
most run a square tire setup so you can rotate tires.... and it doesn't push up front.
On my track only RX-7 it has 18x12's at all corners, 2470lbs wet, just over 600 flywheel HP and it ripped. Big front splitter and a real functional rear wing.
Keep the factory IRS and focus on a proper LSD inside the pumpkin.
Duct the radiator to exit the hood
Big front splitter
Real rear adj wing
Full cage
flat bottom
rear diffuser/tunnels
*that should get you in plenty of trouble... if you want to go faster... focus on aero.... a 2600lbs 240sx with 500hp can be plenty fast that is for sure.
Do not buy a TKO anything... they shift like dog **** especially at higher RPMs. The T56 magnum is much smoother. If this is a track only car... maybe look for a Jerico or G-Force GSR dog box. Save 50lbs+ and much faster/reliable shifts. Granted the dog box is 2x the price or more.
