Road Racing Road Course | Autocross
torque arm
Old May 17, 2018 | 11:16 AM
94LS1B4C's Avatar
Default torque arm
What torque arm setup is everyone running? I've heard of the decoupled if you can find one... BMR/UMI/MWC? also why over factory torque arm?
Old May 17, 2018 | 11:26 AM
ss.slp.ls1's Avatar
I ran a Spohn cross-member mounted, adjustable torque arm for a long time. Aftermarket torque arms are more rigid than stock and having an adjustable feature is good for lowered cars to correct the altered driveline geometry.
Old May 17, 2018 | 11:41 AM
94LS1B4C's Avatar
Thanks for the response, Currently running the stock torque arm mounted to trans cross member with all other suspension components upgraded. In the market for a TA and didn't know which is best.
Old May 17, 2018 | 03:46 PM
HCI2000SS's Avatar
All the ones you've mentioned are good. Founders makes a nice one as well
Old May 17, 2018 | 06:29 PM
landstuhltaylor's Avatar
Strano is selling a decoupled arm off the car he bought a while ago. Would have to contact him directly
Old May 23, 2018 | 10:15 AM
smitty2919's Avatar
I put on a UE decoupled TA for this season (originally was stock), only used it once so far. FRAAX may have someone selling one.
Old May 23, 2018 | 11:23 AM
JimMueller's Avatar
I've used a decoupled TA from a FRRAX vendor since 2004 on my daily driver.
Old May 23, 2018 | 11:34 AM
94LS1B4C's Avatar
How would you describe the difference/or charactoristics sense it's been awhile for you to compare it to anything.
 Michael S. Palmer
Old May 23, 2018 | 11:57 AM
smitty2919's Avatar
My limited use is the car likes to put power down better. I also went to UMI rod end rear LCA's at the same time, but I get more rear end vibration etc into the cabin. The cross brace is tied right under the seats in the floor board so the drivetrain vibration is transferred to you easier.
For me it was more of a "this is a cool design and engineering wise seems like best of both worlds so lets try it". Obviously people have done very well without this style and a simple long TA works for them. I had the money, one was for sale, I like the idea so here we are.
Old May 23, 2018 | 04:11 PM
JimMueller's Avatar
Pretty much the same here. It was a trick piece that had been developed for road course use, and I purchased unit #4 in 2004. Being on the opposite coast of where the DCTA was developed and lack of a real race shop locally made setup a challenge. Sam drove my car at an Evolution performance driving event or two, but the preload wasn't set correctly and it was a bad example. I've read he did try other vehicles that already had the TA setup correctly but he couldn't detect the benefit. I did the best I could dialing it in until fall of 2010 when I traveled to Kentucky for the inaugural LSFest, and another DCTA owner who made his living as an engineer lived nearby Bowling Green, so I stopped by his house and he finished the setup for me.
I haven't driven an F-body in anger with any other type of TA in at least a decade, and I don't know what they feel like any more for a comparison. My setup is far from stock and even then somewhat rare between the DCTA and the shocks so I can't necessarily say any specific behavior is directly attributable to the TA. I've made a lot of changes in the past 6 months, but when I put on the new Rival S tires, I had all the dry traction I could ask for. Throwing pebbles against the wheel well two months later (so far), barely any tire spin in 1st gear at WOT... I'm very impressed with how the recent changes have helped the cars attitude. In general, I think the DCTA works better with suspension bushings that offer less compliance (heim > roto > rubber > poly) and stiffer spring rates, which in turn needs properly valved dampers.
Old Jun 15, 2018 | 09:57 AM
SCCA70's Avatar
I checked Fraax...a member "Brent" has an Unbalanced Engineering decoupled torque arm for sale for over a year with no response..but I can't contact as I'm not a member and no way to find him...if you are a member could you help me with this? thanks, Richard Pryor
Old Jun 15, 2018 | 11:47 AM
smitty2919's Avatar
I messaged you. Send me your contact info and I will pass it along for you.
