Oil
I've been using redline 5w-30 Euro and my oil gets 300 degrees and has-been doing well with 3-4 track days with daily driving in between. Getting ready to install oil cooler and hopefully will get half a dozen track days per change.
I use 5W-40 on the track. Sometimes it's pretty cold in the mornings, and a low "winter weight" works well to get the oil moving quickly. Also helps when the car has been sitting for while. The quicker the oil gets up in to the engine on start up, the better off you are.
You'll get better valve train stability with a 40 over a 20 or 30 weight. My oil never gets that hot, I think I saw 220* once in the last few years.
I would have low oil pressure issues using Mobil 1 5W30 due to the heat breaking it down. Redline solved my issue.
