Progress on my CMC car
I assume no rules against gear polishing in CMC? Also noticed you still have the skip shift solenoid in your case. ICT Billet has an aluminum bolt to fill the hole and knock a pound or two off your weight
But before the motor goes back in, I want to clean and paint the engine bay. It's looked like *** since I bought the car and the core support is a GM replacement that was never painted red. My extra tubs look soooooo much nicer under the hood.
Since you have an earlier trans, did those all have the aluminum 3/4 fork and weaker 2nd gear? I know the early tremecs did but I've heard the Borg's are stronger so thought they might be good form the beginning. Also pretty sure those had the paper ring blockers too? I got a buddy who has one of those and might be rebuilding it soon so wondering what we might be in for.
Found a mess in the oil pickup, but after seeing those decimated valve seals back in June I can't say I'm surprised. I am happy to have that crap out of the oil pickup though.
That doesn't account for all the green chunks of valve seal I scraped out of the pickup, or the metal gravel that I found in the oil filter, oil pan, and just generally everywhere. I'm going to crack a few bearing caps to see how concerned I should be. In theory, this metal should have all come out of the heads, so as long as the bottom end is still happy then game on. I was seeing some scmoo in the pan, and I saw it in the intake valley too. I wonder if this VR1 is light on detergents?
It wasn't gunked up, but this stuff wasn't affected easily by carb cleaner, but it also just wiped right off. This windage tray had seen better days, seems it was about to cause an issue.
Completely broken around the oil pump, and largely separated at the next fastener up. I should have another on the shelf from a Vortec 350 I ripped down. So as much work as it is, I'm glad I cracked this thing open the rest of the way. If it turns into too big of a mess I'm just gonna drop the spare motor in and send it. Fingers crossed my spare can remain a spare.
Last weekend I got all the wiring and crap peeled back off of the fenders.
Here's the 20+ extraneous holes I'm going to plug up.
Here's most of them plugged up.
And here's the problem I ran into when I tried plugging the leftover pinholes.
The area I blew through, for whatever reason, is absolutely razor thin. I'm going to have to weld in a piece of filler behind it to be able to accomplish anything. The rest I should be able to zap in from behind. Next I turned my attention inside the car. This thing is absolutely tearing itself apart.
The bolt and washers is a ghetto rig from many moons ago. You'll see its purpose here soon as I'll be tackling it next. You can see 2 spot welds that are separating as well, there's more on the trans tunnel.
Partway through this repair, I realized my helmet was working properly so I could use my eyes. It usually has a delay that causes me to close my eyes until it shades. Most of these welds are too quick for that to happen, so I end up doing it blind. Next was this crack that had propagated quite a bit since I last laid eyes on it.
For years it was nothing more than the smiley faced bit.
This one went pretty quick, since I could use my eyes I even welded a hole shut that I created with ease. Next was this new one.
I got it good up top, but blew through on the bottom. Probably going to stay that way. Here's what is letting go on the trans tunnel.
Looks OK in this pic, but those top 2 are separated.
Lovely. How much you want to bet I blow through as soon as I hit the trigger?
The washer is .075" and the core support is .045" if I haven't whacked it with the sanding wheel.
As expected, ran into problems up front. So I cut out another washer in a half moon shape and zapped it in.
It may look crappy, but there's good penetration there.
This site was easy, one and done, and also where I got the hang of manually pulsing the welder. My helmet complied with this technique so it came out pretty good. I applied this technique to the other side when I did the half moon and second pass on the main piece.
Here's the chunk of "nut" that was attached to both washers. I was scratching my head, wondering what in the hell it was the PO has installed to retain the pins, and suddenly I saw the answer staring me right in the face.
Slick as that little dingus may look, it will fatigue out in a hood pin application with enough nose to tail contact. I think my version should age better.
Total cost? Crap I had laying around. Hopefully tomorrow I can get the rest of the holes on that shock tower zapped shut. It'll be cold, so will wait for warm weather to return before I prime and paint the engine bay in prep for whatever motor goes back in.
Now for some before
And after shots. I dumped a can and change and came up short, gonna need another to get this good and done. I pressure washed this thing like 4 times today trying to blast away at the filth. The car will never be this clean again.
Having 2 other shells, I know what they're supposed to look like, but even seeing this much is surreal. It looks soooo much less like a piece of crap.
Now to muster the motivation to deal with the paint you can see from the outside.
