Road Racing Road Course | Autocross
Accusump install
Old Sep 23, 2025 | 04:55 PM
Orange Juice's Avatar
Default Accusump install
Where is the best place to put the oil feed off of the engine. Not much room under the header. Is there a sandwich plate that works on a stock 4th gen oil pan?
Old Oct 28, 2025 | 10:31 AM
Kubs's Avatar
On my C5 I ran it to the pressure sensor behind the intake, and remote mounted the sensor. Will that fit in a 4th gen Camaro?
Old Nov 10, 2025 | 03:45 PM
Thanks, I don't think so, Its a very tight fit back there on the Fbody
Old Nov 17, 2025 | 09:20 AM
tallrandyb's Avatar
Thumbs up
LS or LT? I'm running a oil cooler sandwich on the side of my LS pan for a 94 Formula, with lines running into/out of the front. I've put a T into the return line with a one-way valve in front of it to insure the Accusump only pressurizes the block and not towards the cooler. Yes it's tight under there but you can get creative.
