Installing Tow Hooks
<strong>I have seen a full out AutoX car and his front loop bolted to the front inpack beam. So cut the foam and make it line up with the opeaning in the nose. a little hard with out Wing West panel or none.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Thanks. I have the Wing West Panel, but I'm going to cut the foam on both sides to make two air intakes to feed the open K&N filter that hangs in front of the radiator. Here in NY we have a front plate so I guess I'll have to drill a hole in it to get the loop anchored to the beam unless I can come out below the plate.
