Road Racing Road Course | Autocross
Cooling question
Old Nov 23, 2002 | 07:19 AM
JackZ28's Avatar
Default Cooling question
Do any of you use an oil or fuel cooler? I saw these advertised somewhere, but I had never heard of anyone using either. Is either recommended? What would be the ideal set up be for a car that road races almost every weekend?
Old Nov 24, 2002 | 12:06 AM
2FAST4U's Avatar
Default Re: Cooling question
NO I don't but I am going to run a oil cooler but thats because the oil from the turbos gets dam hot!! My fans on/off points are lower and I will uses water wetter. If the water temp is still too high next will be fan switch and then better radiator (not the cheap slp).
