Road Racing Road Course | Autocross
A4 f-bodies
Old Feb 3, 2003 | 04:53 PM
roy's Avatar
roy
Default Re: A4 f-bodies
Yes they can , Are you gonna upgrade the cooling aspects of tranny?
Old Feb 4, 2003 | 12:44 AM
Fbody Man's Avatar
Default A4 f-bodies
can a4 f-bodies be used in road racing also. Just curious if automatics can do this to <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Old Feb 4, 2003 | 11:46 AM
Louis's Avatar
Mike, aka 4WheelDrift, runs his auto consistently with the Texas guys. Ill send him over here and he can answer any Qs you have <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Feb 4, 2003 | 08:55 PM
DriveATransAm's Avatar
ive done it once. your trans will get extremely hot, and you will be on your brakes hard and often. it can be done, but its not as easy as a manual.
http://home.attbi.com/~royboy82/ra.htm
Old Feb 6, 2003 | 07:10 AM
99HOSS's Avatar
I've run in open track events since Oct 99. I've added a second cooler in front of the AC condensor to run in series with the factory cooler. I just leave it in drive and go. I know how far I need to go, with the foot, to drop it down when needed, so you're not shifting manually.
As far as brakes, you'll use just as much brake as you do with a manual. The way I learned to drive on track is to use the brakes to slow the car, not the trans. You heel 'n toe a manual to be in the right gear when you exit a corner, not to slow you down to enter it.
My 'other' F-Body is a 3rd Gen T/A.
<small>[ February 06, 2003, 07:15 AM: Message edited by: 99HOSS ]</small>
Old Feb 10, 2003 | 02:06 AM
TomQ's Avatar
i have vig 3200
stock tranny
B&M cooler up front of the car
B&M deep pan
do you think i should be fine on a road race course ?
Old Feb 11, 2003 | 07:00 AM
99HOSS's Avatar
with the exception of the convertor (3200 stall) you'll be fine. you'll just have to keep the rpm's up there to stay hooked.
Old Feb 11, 2003 | 10:02 AM
TomQ's Avatar
yeah i know,huh, with so much stall it's like -- damn <img border="0" alt="[barf]" title="" src="graemlins/gr_barf.gif" />
