Firehawk
I'm looking to make the jump into open tracking soon with my 2001 Pontiac Firehawk. I've done quite a bit of Karting so I've definetely got the road course bug, but at the same time, my budget is still more toward the karting side as opposed to the car side.
My car, as stated, is a 2001 firehawk with the Bilstein suspension and the normal intake/exhaust/shifter mods. Naturally I'd expect to have to purchase some road course tires, but what else to get into some open tracking (such as BMW CCA type events or whatnot). Truthfully, I'm not sure what I'd like to get into, but I think I'd like to do something on a full road course as opposed to autocross. Limerock park is about 3 hours from my house so I'd consider that a "home" track where I'd most likely be running, at least I think.
Whats the bottom line as to how this car is in baseline form, and if there were a list of "most critical" mods to make, what would they be. Obviously upgrading the driver comes first, but I've done pretty well in the karts, so hopefully a bit of that will carry over.
Bottom line is, how is this car as a baseline, and what is most critical to be changed?
-T
Once the brakes are addressed,,, I think that shocks will be the most bang for the buck on these cars. Either Koni or revalved Bilstiens would work well depending on how much you want to spend.
In any event, remember that the Bilstiens are not ajustable and you need to figure out which springs you are going to run before buying the shocks. With the Koni shocks, you have a little bit more room to play with spring rates. Try to get an idea which direction you are going to go with the car. That way, you will not have to be buying things over and over because you changed your mind on what you will be doing with the car.
As far as what I want to run - I'm not sure - nothing too extensive. If I want to get more serious I will buy another car, probably a formula hard top or something like that - I'm not gonna rip apart a beautiful firehawk and make it a race car, I'd like to just use the car to get my feet wet for open tracking/lapping and improve my driving skills. As I mentioned I've beeni nto Karting for a while now, so I'm pretty serious about running the road courses.
So as I read this, we're talking about SFCs and Brakes as items # 1+2, with of course Tires being #0. Any reccomendations on the best bang for one's buck when it comes to SFCs and Brakes?
Thanks alot!
-T
https://ls1tech.com/forums/road-racing/202164-setting-up-ws-6-handle.html
Refer to Cal's post, #5 and 01whitez28, #2.
Steve
I'm not looking for how to set a car up, because at this point I'm not even sure what I'm setting it up for. I want to get onto a road course, run some laps, and decide from there. I was looking for a list of one or two "most critical" mods to make, and I got some recommendations, and was simply looking for others' opinions on the best bang for the buck with regards to the SFCs and a brake setup.
I'll glean what I can from the other posts, thanks.
Frame supports, suspension,
etc, etc
