making the convt handle
its a 99 a4 t/a convt (yea best chioch to road race right
) but i have about a few bucks to play with and just looking to see what would be the best route for me SFC's and ProKit is the best place to start for the money. From there go with larger swaybars.
Jason
didnt think of subframe connectors well didnt know what they hell they did either way.........sorry yeah very newbish
Jason
The best gain I got BY FAR was when I installed the ST 35mm front sway bar (~$175). I also lowered it with DMS progressive rate springs (~$155) (almost ~2" drop). That helped too, of course. A panhard bar with heim joints (~$150) gets rid of some of the tail-happiness when doing quick left-right-left maneuvers. Shocks will help too. They need to be valved to match your springs for best results. I recommend Bilstein HD's(<$500). They're relatively cheap, good quality and can be revalved/rebuilt.
For under $1,000 you can handle like a Vette. Maybe a stock Vette - lol. j/k but it really doesn't take that much to make an F-body handle well, even if it's a vert. I think they have better front/rear weight balance with the top down anyway. lol
What is the car doing that is "holding you back"? What tangible data do you have that supports this? tire pressures? tire temps?
What is your goal? AX? RR? OT? What venues will you be running?
How much experience do you have behind the wheel on a AX course or a RR track? It has been my experience that if a car is pushing really bad, it's because my right foot is too heavy and I over-cook the car going into a turn. If the tail gets happy on corner exit, again, my right foot is too heavy.
the things that are holding me back are the tail happy rear end and lots of roll
and yes i do have a heavy foot more like lead but i know my limits and experience basicly nil............but like i said i am a newb and i was looking for answers from the right people ie.road racing and autocross guys
also does anyone know of where i can find some local autocross races in central cali?
Find an evolution school to attend and make sure your problems aren't driver induced. If the driver sucks, an F1 suspension under your car will still roll and oversteer.
The absolute cheapest modification that can be had is education. A lot of folks have too big of an ego to admit they might be overdriving the car.
i never said i could drive my car all that well but i do know once i get better suspension i will be able to handle it alot better than i do now but thats just a fact no ego what so ever
and thank you for the link
Having followed his posts on various forums for years though, I do know that he has an extreme amount of knowledge on the subject of making these cars handle, and the link he gave has some great information as well.
Good luck with the convert, keep us posted.
If you are on a budget then forget about buying new springs. Cut 1/2 coil off the bottom of each front spring with an angle grinder using a cut off blade. Try replacing the rear spring isolators with hose (5/8 ID?)
1- alignment 0 toe -1.5 camber (but you might want to wait till after installs below)
2- shocks
3- weld in sub frame
4- 35 mm front bar
5- 315 tires front back
6- rod end adjustable panhard bar (required for #5)
That will be your biggest bang for the buck. Frankly, I wouldnt drop more into your car unless you wanted to switch over the trans to M6.
