Brake THIS...
How often have you had to rebuild or replace seals on the calipers?
I looked into the LG Wilwood kit as it is priced well and fits under Z06 front wheels. But I picked up a Mov'It Brembo kit used for less than LG advertises and am very happy so far. The Mov'It kit does clear 01 Z06 wheels.
Mov'It uses rotors and 4 piston Brembo Big red calipers off a 993TT using a custom bracket to hang the caliper and center hub on the 2 piece rotor. The newer kits use 996TT Brembos and slightly larger rotos.
http://www.movit.de is Movit's page they do offer 6 piston packages.
http://www.ultimategarage.com/ sells the kits new.
