Road Racing Road Course | Autocross
Oil accumulator questions
Old Sep 17, 2006 | 11:43 PM
Judd's Avatar
Default Oil accumulator questions
It's been awhile since I've post on here {was without the Firebird for awhile and got back into sportbike trackdays} but if any of you remember me, I hurt my motor at Road Atlanta last spring. I decided to build a "good" and I have it done now. I also finally got around to checking out my old motor and discovered that it spun a rod bearing. I was running M1 5w40 at the time and do not thing the oil contributed to the problem. I do however think it was a oil related problem though. I generally over filled it by .5 to 1 quart so I don't think that was it. I still have the stock gages {gonna fix that though} and I think I was having oil starvation problems when braking and cornering hard. I figure the stock gage was reacting so slowly that I didn't notice it.
I didn't discover the rod bearing failure until the new motor was already in the car {I know, I'm lazy} and I really don't want to remove the engine just to throw a road race type pan on it. That is why I'm looking into oil accumulators. Moroco has a 3 qaurt version that looks promising. I know absolutely nothing about these things, anyone got any experience in them? Accusump, Moroso,,,, any of them? The engine that is in it now really is a well built engine and I want to ensure that nothing as mundane as oil starvation due to cornering destroys it.
Old Sep 19, 2006 | 09:18 PM
matula11's Avatar
i have a 3qt accusump on my car. i bought the whole setup, motor and accusump, from a guy on here. i was thinking about running it, he had no problems with it, but now am leaning toward a road race pan. i don't know if that helps you any. but if you do decide to go that route, i will probably sell the accusump here shortly. let me know if you want it. good luck with whatever route you go.
Old Sep 20, 2006 | 01:02 AM
Judd's Avatar
Shoot me a PM on entire set up. Break down exactly what you have by part numbers if you can.
Old Sep 30, 2006 | 07:42 AM
Speedpup's Avatar
they work great I have a 3 qt in my Vette after popping a motor. No more problems in 5,000 track only miles.
Old Sep 30, 2006 | 11:20 AM
LS1-450's Avatar
I have an oil accumulator also. You can't go wrong with an accumulator. It can be used to pre-lube the engine prior to start-up (no start-up engine wear), as well as, motor protection under high RPM, extreme braking, cornering, slopes,.....etc.. Would highly recommend one.
Old Oct 3, 2006 | 05:43 PM
gnx7's Avatar
When road racing I would always run 7 quarts (F-body pan) and never had a problem. 285/30/18's at all corners.
Accusump is a good idea though for sure!
Old Oct 3, 2006 | 09:19 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Any pics of your mounted accumulators?
Old Oct 4, 2006 | 12:57 AM
Judd's Avatar
It'll take a week or two for mine, I'm just getting the parts up. I will be moving the battery to the trunk and mounting the can there. I will be using a remote cable actuated manual vavle for pre-lubing.
Anyone with any pics of their set-ups?
Old Oct 4, 2006 | 08:06 AM
SRZ's Avatar
SRZ
Mounted mine here.
Old Oct 5, 2006 | 12:08 PM
LS1Tech Co-Founder
I know one of the turbo guys runs a 1.5 Moroso, I was going to get one.
Old Oct 6, 2006 | 03:03 PM
GR33N GoblinM6's Avatar
I have a friend using an accusump on his Road racing (dont laugh, its fast and well built) 90 integra, turbo'd.. makes 293hp at the wheels(front wheels)
pretty nice system..
