Best Suspension set up for
Just remember that you could drive a C6.R into a corner at 180mph on a set of the donuts you have as your spare tire, but if you don't have a decent set of brakes on that car...safety first my man
Here's what I learned from research:
Dampers: Koni SA or DA
Springs: Hotchkis
Roll bars: Strano proprietary
LCA's: You can get adjustable with spherical rod end on one end, bushing on the other (see Spohn or UMI). Ask around for LCA choice. People have different preferences.
Panhard Rod: Get one.
Tq. Arm: SLP adjustable (see what degree the RR guys are dialing in for pinion angle).
Tires:try these for a good all around tire...Goodyear Eagle F1 GS-D3 which is good in the wet and can sutain heat cycling.
Get good pads: Hawk HT-10 up front, Blue in back (or comparable).
Fluid: Motul RBF 600 or ATE Superblue bled day before lapping.
Rotors: Run what you have or spend on some floating rotor if there's availability for our cars if you wish to spend money on this item.
Very important! Brake ducting to cool your front rotor and hub.
Alignment.
from the research I found ...
For the front suspension ...
Tubular K-member
UMI has supposedly built a unit to handle the loading the front end will see under this kind of torture. It's still young on the market ...
And why are you using a V6 to start with? Lot's of V-8 cars out there for $500 or less. I bought a 96Z from a guy in Houston about 6 months ago.
Bolt in roll bars typically attach in the passenger foot well and either the rear fender well or the flat behind the rear seat. That is the thinnest parts of the uni-body. Not much protection.
We weld in the bars on 120 in/sq base plates on the base where rear seat mounts and just behind the rear shocks. All these points are multiple, sandwiched layers of metal. Much stronger base.
Try softening the shocks up first since they are adjustable in both compression and rebound. Listen to Mitch on the rollbar and K member. Eradispeeds are not for track use; get replacement OEM style rotors, real front brake pads (call Larry at Carbotech eng.), real brake fluid (Castrol SRF), and real power steering fluid. Your OEM cooler should keep the PS cool, but puts that heat into the cooling system.
Next thing I would replace is the panhard bar with an aluminum dual rod end PHB. Better tires will help. The Nitto NT01's look great on paper. After that it gets serious.
I personally think stock K and A-arms are decent from the factory. On a street tire car, I do not think the gains would justify the expense.
As for tires that work in wet, you really need to compromise ultimate performance (like I did). The NITTO 555s I have perform well at the track, and fine in the rain (although not so great in the cold-even when the road is dry). This is to be expected of a high performance tire. I think my lap times would b better w a lower treadware tire, but you cannot have it all. I'll am willing to give up some track prowless for not being afraid should my wife get caught in the rain w it.
Things that "need" change IMHO--Shocks(Koni SAs)-Panhard Bar(single adjustable w rod ends)-Sway bars(Strano Bars)-Alignment(NOT stock)-and a brake upgrade.
I haven't done the brakes yet-but I will soon. Cannot speak from experience, but I would say at least a high quality pad w quality rotors, or a C5 upgrade if you like.
Oh, and check out http://www.frrax.com/rrforum/
It has some serious handling tech. I love LS1Tech, but its mostly DDs and drag racers. Most the handling guys here are also posting on FRRAX...again-very serious tech there! In fact I mostly read there, beacuse I am humbled by the knowledge there!
Will different springs help? Or should I just keep the ones that are in there on I think they are eibachs Im sure I seen it on the the springs.
Seems like I dont qualify. So Does it mean that I am better off getting new shocks to replace the ones I have?
http://chuckb.1le.net
