which is the priority: less weight/ or weight balance?
-Chris
The suspension can be tuned to counter a weight bias imbalance.
Getting rid of "convenience" items like head lights and the associated infrastructure, pruning the wiring harness, moving the computer and associated wiring, moving the battery, chunking the windshield wiper assy ... it will always be very nose heavy.
After going to those lengths, my TA is still 52/48 F/R bias
I would suggest not adding weight to try and achieve a different driving characteristic. I aim for less unsprung weight and let the way tire pressure and sway bar settings deal with under/over steer. This gives a more controlled reference.
What tire pressure would you use to minimize weight bias?
My '93 FD RX-7 with LS1/T56 (no a/c or p/s): 49.5% front/50.5% rear 2950lbs (with driver/full tank of gas). The crossweights were within 1lb of each other after corner balancing.
285/30/18 MichPSCup tires all around with mellow street alignment= 1.13g's
It will take a UMI K-Member and serious carving of body structure to get that last 75-100lbs ...
With an LS1 car, it would definitely be easier.
