Road Racing Road Course | Autocross
Performance Alignment?
Old Sep 11, 2007 | 11:27 AM
Arctic2002ss's Avatar
Default Performance Alignment?
I am getting the SS aligned and am thinking I should have them do a "performance alignment". You know, to make it corner better. It is mostly street driven but I also do HPDE events and like to corner. Good idea or no?
Old Sep 11, 2007 | 11:32 AM
MeentSS02's Avatar
Kleeborp the Moderator™
Define performance alignment...performance alignment to their specs, or yours?
I'd say it is a great idea as long as you are providing the specs...I'm just not sure of who I could trust around me to do it (I don't think most tire shops would be willing to work with me on it).
Old Sep 11, 2007 | 12:28 PM
Well see, that's my problem. I admit that I don't really know what I'm talking about and certainly don't know the specs. I'm seeking some good info here.
Old Sep 11, 2007 | 01:19 PM
Ojustracing's Avatar
-1.5 Camber, 4.5 castor(Or more is they can get it.), -.05 toe. would work real nice. But depending on how low the car the camber might be hard to get. It depends on the car. I will tell you to get max tire life tire rotation every 3-4000 miles. I hope this helps.
John
Old Sep 11, 2007 | 01:24 PM
MeentSS02's Avatar
Originally Posted by Ojustracing
-1.5 Camber, 4.5 camber(Or more is they can get it.), -.05 toe. would work real nice. But depending on how low the car the camber might be hard to get. It depends on the car. I will tell you to get max tire life tire rotation every 3-4000 miles. I hope this helps.
John
Is one of those cambers supposed to be a castor?
Old Sep 11, 2007 | 01:31 PM
Killer_Bluebird's Avatar
4.5 is castor. On stock ride height your maximum camber is about -.75 or so.
Old Sep 11, 2007 | 02:16 PM
Oh, I am on the stock springs and mostly stock suspension except for Bilstein HD shocks. Should a good alignment guy know these numbers or are they f-body specific? Thanks for the information.
Old Sep 11, 2007 | 02:40 PM
These setting are F-body Specific, but like Blue said you are only going to get about -.75 or so for camber at stock ride height.
John
Old Sep 11, 2007 | 04:50 PM
So it sounds like I should just get a good alignment and quit thinkin about this stuff....
Well, maybe if I start modding specifically for road racing.
Old Sep 11, 2007 | 07:40 PM
Arctic these setting are not stock. If you go to a place they may set it to factory specs that are different from what we gave you. You need to go to a place that will listen/do what you want. The chepy tire place might not take the time to adjust things the way you want. Make Sure you get a Print out of before and after.
John
Old Sep 11, 2007 | 10:47 PM
Mojave's Avatar
If you are at stock height, it is easy: max negative camber, max positive caster, toe: anywhere from 0 toe to 1/16" toe out. More toe out wears the inside edge, but improves turn in.
Old Sep 12, 2007 | 12:02 AM
Greggy's Avatar
+1 except for zero toe for street driving.
You'll love the improved bite you get out of the front.
I've been messing around with home alignments and think I like -1 deg. camber, +4.5 to 5.5 caster, and 0 toe for a good compromise of tire wear, twitchiness, and grip.
The optimum alignment varies though with driver preferrence, driving style, suspension setup, tire type, tire size, pressures and road surface. But most people find these settings to be much better than stock.
Old Sep 12, 2007 | 09:14 AM
Thanks guys. I am taking all of this good information with me to the alignment shop today.
I think that the car has had something a little off in the alignment since I got it and my new GSD3 tires are really making it noticeable. The GSD3s do feel really good in the corners though. I will find out for sure at an HPDE this weekend.
Old Sep 12, 2007 | 09:33 AM
Mojave's Avatar
Have you run @ TWS with Driver's Edge? I seem to remember a guy there named Craig with a white SS with cam/headers.
Old Sep 12, 2007 | 10:36 AM
Yeah Chad(right?), that's me. I went to MotorSport Ranch the last time and am running it again. It's closer and I like the track better although it's slower and tighter than TWS.
Old Sep 12, 2007 | 11:36 AM
Mojave's Avatar
Yeah, that's me. I want to go to MSR-C, but I'm afraid to drive my car there for fear of it breaking and not being able to drive it home. And TWS is so close; makes it hard to drive 3+ hours when I can just drive 4 miles to TWS.
A good alignment should really help your car, especially if you have a stock alignment now.
Old Sep 12, 2007 | 08:52 PM
DriftZ28's Avatar
If you don't mind me asking... How do you adjust caster on f-bodys? My alignment guy doesn't know how.
Old Sep 13, 2007 | 12:06 AM
Mojave's Avatar
There are 2 bolts that adjust the camber/caster specs. The camber bolt points front to back, and it is the bolt closer to the front of the car that supports the control arm. The caster bolt points from top to bottom, and is the rear bolt that supports the control arm. Both of these bolts have slots that allow the lower control arm to be moved. First, loosen both bolts. Then, set the camber where you want it, and tighten it just a little. Next, you can move the caster bolt. You can't measure caster directly (have to do a caster sweep), but more caster is always good for an f-body at or near stock height. Pull the control arm out from the inside of the car. This will give max positive caster at the given camber setting.
Most f-bodies are limited to what specs they can get stock. Getting good camber is more important than caster. First set camber, then caster, then set the toe. The toe change may slightly affect the camber reading.
Again, if your car is at or near stock height, max out camber and caster. Pull the control arm as far out as possible to give maximum.
Old Sep 14, 2007 | 02:29 PM
jhelms's Avatar
+1 on those last numbers.
Good comments here.....
