Car Prep?!
New fuel Filter...(What kind?!)
New Brake Fluid....(What kind...)
Bearings?...Somebody mentioned to me the first thing I should do when involved with any type of racing is replace the bearings...
Injectors?...
Plugs?....
Stainless Brake Lines?
Future mods are: Kooks Headers, ORY, SLP Subframe connectors, and SHOCKS (what kind....)
Let me know what you think about this maintanence list thanks.
Injectors?...
Plugs?....
Beyond that ...
Run 7 qts of motor oil
Never get below 1/4 tank of gas and you will use a LOT of gas ...
If you go with something less than Castrol SRF, you should probably consider burping the brake fluid after each day.
Exchange the stock PS fluid with Redline. Don't fill it past the "ADD" mark. It will burp out the cap.
I also suggest you put a Redline gear oil in the diff. I use 80W140 because of the heat buildup in the rear.
You also might find you will consume an amount during a session. I will use 1/4 - 1/2 a qt in a 20 minute session, depending upon how high I rev and how much compression braking I do.
FWIW ... I have ZERO consumption daily driving.
And I use 6qts when I daily drive it. You just never know when you will "need" to take a high G corner or do a lot of compression braking.
And when I say you will use a lot of gas, I mean you could easily use 1/4 in a 20 minute session. My on track mileage is around 5 or 6 mpg.
FWIW, I got 4.5 mpg at TWS last weekend. I got 7 at MSR.
You have to remember, I've got 70K+ miles on that fossil lubricated motor ... the last 3 years of it has seen hundreds of laps and thousands of miles on local road courses.
For a fuel filter, I use their CM-15 GM EFI fuel filter #25-909. It filters down to 1-8microns. It flows 90gpm, and snaps in place of the factory unit. It kicks the sh*t out of the stocker.If you haven't heard of Canton Racing, they designed the oil pan for the Cobra R's. They've been around a long time, and their stuff works. What's funny, is that the Ford, and racers know about em', but the GM guys don't, simply because it's not in GM High Tech Performance. Go figure. Hope I helped.
I hope I'm accurate in the above assessments.
Regards
Steve
Those are all very valid points.
I have not seen an aftermarket oil pan for the LS1 (but I'm looking). I believe that GM considers the oil pan "structural" on this motor and it is supposed to be installed with special alignment tools (as I remember reading...I've not met anyone who has used said tools). I considered trying to adapt the corvette pan and manifolds (to clear the pan), but have done absolutely no research on this subject so far (I'm getting to it...). So, if the partsare available, you have a "better" idea....If anyone has seen oil pans, let me know where to get one....(please!). I was considering a canton accumulator (accu-sump) and a remote filter setup for my car (until a better mousetrap is built). Just my thoughts.
I started doing it in 2001 when a local road course recieved 5 SS Camaros as school/track cars from GM.
After the school popped it's 3rd motor in the first month, the GM engineer sent to the school for a motor inspection said to run an extra qt of oil.
I heeded the warning ...
I also run a high volume ARE oil pump. So it sucks a lot of oil out of the pan ...
I'll have to give them a yell.
Mitch, do you drain some oil out of your car between visits to the track or does the high rpm use enough that it is unnecessary?
Regards
Steve
I put 7 and a filter in before the weekend begins and change it with 6 and a filter immediately after.
Oil is the cheapest amintenance one can do. I change it often. But, I don't use a synthetic because of that. Tests I've had done has shown that the oil I'm using is holding up very well for the short time I use it.
For example, I put 325 miles on the last oil change and used about 1/2 qt over he weekend. My theory is that the trash that is absorbed into the oil from combustion and normal wear is much more harmful than any viscosity breakdown.
I have another weekend planned next weekend and will have no more than 600 miles on this change.
I just finished making some custom brackets to mount a 5 stage Barnes pump to my LS1. I am using the ARE pan modified to fit over my BMW crossmember. I bought almost everyting used and still have almost $2K in the oiling system. For new, I would expect somewhere between 2 and 3 times that figure. Am I reading that right? LS1 in BMW?
Sweet!
Kevin
