9in taking curves...
Hi.
When I went to my frist autocross, my 9in drop some fluid after frist round, Then we taped that hole only for that day. How can I fix that problem?
![](http://i104.photobucket.com/albums/m186/ANNEKLEIN/hz/9in1.jpg)
![](http://i104.photobucket.com/albums/m186/ANNEKLEIN/hz/9in.jpg)
![](http://i104.photobucket.com/albums/m186/ANNEKLEIN/hz/9in2.jpg)
![](http://i104.photobucket.com/albums/m186/ANNEKLEIN/hz/9in3.jpg)
I had the same issue with my 12 bolt at an autocross.
I put a vent hose on it that I looped up over the top of the center section. that way when the axle tube fills it trys to push it up hill and back against the g forces. It never leaked again. The car is not here or I would take a picture for you.
Hope that helps.
Hope that helps.
