Moser 12 bolt and road racing
I installed a 12 bolt on my z28 a couple of years ago. Recently I started turning the wheel while I'm racing. I've also started to wonder whether having that rear end is going to be a positive or negative on a road racing set up -as compared to the stock 10 bolt.
Any insight would be appreciated.
The extra unsprung weight is definitely not helping things, but it's not really a big deal. The most important part is getting a diff that works well for turning, like a Trutrac or similar. Lockers and spools generally cause it to push on entry and get loose on exit.
OK, so did a little more research... what I have is the 33 spline eaton posi 4 series unit. Its not at truetrac... but its not a locker or spool.
Will this give me any advantage or disadvantage compared to the stock 10 bolt (I have 4.10s for what its worth)?
I say go do some track events before worrying about messing with anything.
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
I'm not sure how that diff works, but if it works half-way decent (I bet it does), then it won't be a problem. If the diff has a lot of bias, I could very well work better than the stock T2. I would guess worst case it doesn't work any worse than a stock T2. Overall, your gear ratio is *probably* not ideal for most tracks, but it really isn't a big deal, especially when you are just getting starting with HPDE. So, you are going to have a bit more unsprung weight, which, when you are just starting out at RR/HPDE, won't be noticeable at all.
I say go do some track events before worrying about messing with anything.![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
Cool, thanks man.
The car is already A LOT of fun on the track... stock brakes and suspension are having a hard time keeping up with the power, but its a blast, especially coming out of the corners. Biggest downer at the moment is having the Nitto DRs on the rear, makes drifting a challenge. I've already spun it once after snap overstear caught me - fortunately I stayed on the track. I'm not going to try that again until I have some less grabby tires on the rear!
Actually, I think the eaton is supposed to be one of the better ones for this.
For the brakes, look into better pads. I just have aftermarket rotors, ceramic pads and high temp fluid and it does way better than stock. I have only really had mine fade once. That time was early in the weekend and I think they were glazed or something. They did great the rest of the weekend.
Have you heard of/been down to Harris Hill Road in San Marcos?
