Easiest way to check lifter preload?
Old Apr 22, 2006 | 02:49 PM
98 Raptor TA's Avatar
Default Easiest way to check lifter preload?
What's the easiest way to check lifter preload? I'm not sure my pushrods are the correct length so i wanna check my preload and make sure i get the right length pushrod in my TA.
Old Apr 22, 2006 | 03:35 PM
vettenuts's Avatar
Either with a dial indicator, or if you can tighten the rocker until you just take out the lash, then tighten it until the slop it out of the rocker bolt (don't torque) so that you are compressing the lifter. Multiply the number of turns by 1.65 (this is from the parallel triangle formed by the rocker stud and the pushrod from the valve stem) and then by .049 (I am basing this on a metric thread pitch of 1.25 mm per thread, so 1.25 mm = 0.049").
So, 1/2 turn would be 0.049/2*1.65 = 0.040
Old Apr 22, 2006 | 03:41 PM
So how do you use the dial indicator to measure it?
Old Apr 22, 2006 | 05:03 PM
92zcamaroperson's Avatar
hehehe
Old Apr 22, 2006 | 05:09 PM
Originally Posted by 92zcamaroperson
hehehe
Sorry, i've never used one before, i'm sure it's easy, but i havent used one, so that's why i ask.
Old Apr 22, 2006 | 06:04 PM
oange ss's Avatar
run rocker bolt down to 0 lash on lifter, position indicator pin on pushrod side of rocker arm, zero out guage, torque rocker arm bolt to recommended spec, veiw guage for preload info
Old Apr 22, 2006 | 06:05 PM
oange ss's Avatar
maker sure lifters are on base circle of cam
Old Apr 22, 2006 | 06:07 PM
that's what i figured, just wanted to hear it from someone who's used one before.
Old Apr 25, 2006 | 08:36 AM
usd2sing's Avatar
gonna ask a question here....
what about the issue of not having the lifter pumped up with oil?
say new lifters being installed during cam swap. or if you pulled your lifters and they had some drainage. sometime just priming isnt enought to get an accurate reading.
from my (limited) understanding it can make a large diff...
Old Apr 25, 2006 | 10:06 AM
oange ss's Avatar
it can, make sure lash is at 0 when checking, you'll know if you go too far
Old Apr 25, 2006 | 11:55 AM
777's Avatar
777
Buy a pushrod length checker. $20 from www.ls1speed.com
Old Apr 25, 2006 | 12:08 PM
ArKay99's Avatar
That's the easiest way. Either way always make sure the lifter you are measuring is on the heel of the cam lobe. If using a dial indicator, do as stated above, but wait for the lifter to bleed down approx 2 mins. before you read it. You can watch the indicator slowly sweep around until it stops.
Old Apr 26, 2006 | 06:34 AM
02RedHawk's Avatar
Can you elaborate a bit more on the calc? That is, where's the 1.65 multiplier come from....I'm not following the "parallel triangle" description...
Or is this calc the correction for the 1.7 ratio rocker - holding the tip of the rocker at the valve fixed & drawing an imaginary line from the valve-tip to the pushrod-end, there is then a "triangle" generated as the rocker bolt is tightened & its amplified effect on the pushrod....?
Thanks!!!
Old Apr 26, 2006 | 06:41 AM
02RedHawk's Avatar
Wait, I think I understand it now, after throwing it on paper... But I think the "1.65" should actually be "1.70" (our rocker ratio), yes?
Old Apr 26, 2006 | 07:59 AM
jetblast's Avatar
i just placed midget magic markeron the flat surface of the head with the tip on the p/r made sure its steady and then tightened the rocker arm. measured the mark it left behind. bleed down of the lifter,zero lash and cam location are part of this check and fixied rocker arm design.
Old Apr 26, 2006 | 08:42 AM
GuitsBoy's Avatar
No, 1.7 is when going the other way. I get 1.588 being the ratio in this direction. How about this: Every 360* of the rocker bolt past 0 lash is .078" of preload.
Old Apr 26, 2006 | 10:28 AM
02RedHawk's Avatar
Bingo. I like it.
