Lockup convertor in 3rd at WOT using Edit?
Old Oct 15, 2002 | 09:17 AM
quickWS6's Avatar
Default Lockup convertor in 3rd at WOT using Edit?
Is there anyway to program the computer to lock up the convertor at WOT when I hit third gear using LS1 Edit? Or do I have to use a lock-up switch?
Old Oct 15, 2002 | 08:58 PM
Ragtop 99's Avatar
Default Re: Lockup convertor in 3rd at WOT using Edit?
yes. You can do it in the TCC tables.
Old Oct 15, 2002 | 09:21 PM
SIKLS1's Avatar
Oz Director
Go to Transmission Calibration>A4TCC>TCC MPH Threshold look at the 3rd gear Apply threshold and set to your Mph you want this to be.
Or edit the Normal Mode MPH vs TPS% or the
Performance Mode MPH Vs TPS% and edit the 3rd gear lock up at a percent of TPS per step, if it has 255 in every box this is the miles/per/hour the car has to reach before lockup.
Old Oct 15, 2002 | 09:44 PM
MMarquez's Avatar
That's Cool. How much more trap speed would one pickup in the 1/4?
Old Oct 17, 2002 | 08:18 AM
JS's Avatar
JS
It will still lu at different rpms from run to run?
I;ve tried it and its not as good as a switch...
JS
Old Oct 18, 2002 | 10:21 AM
Ragtop 99's Avatar
Trap speed gains from 0 (very efficent converter) to 2 mph.
Old Oct 22, 2002 | 02:38 AM
pontiaddictws7's Avatar
has anyone tried locking the verter with Edit for dyno tuning? wheres a good speed to do this?I have thought about this but never sat down and worked with it.
Old Oct 22, 2002 | 05:45 AM
PlowTown Missile's Avatar
I'm locking my converter (stock) up using LS1Edit at 75 mph. No numbers on if its helping though. It does seem to pull harder up top. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Old Oct 22, 2002 | 08:11 AM
Edge Hawk's Avatar
I know some people lock up the TC at 50 mph in 3rd and 4th.
I might do that, but unlock it at 140mph in 4th.
top speed:I went from 147 stock stall to 152 with the 4k.
when it shifts into 4th, you feel it, not like it's dying, but waking up.
Old Oct 22, 2002 | 09:20 AM
Ragtop 99's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by pontiaddictws7:
<strong>has anyone tried locking the verter with Edit for dyno tuning? wheres a good speed to do this? </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I do.
around 50 - 80 mph is fine for use on the dyno depending upon your gears. Dynoing on an unlocked high stall converter is just about worthless from a tuning perspective because the converter shift's extension does not allow you to tune the midrange and results in a skewed rpm & torque readings.
Old Oct 22, 2002 | 10:58 AM
ragtop
thats what i was referring to ,I have a 3:73 with the VIG 3600 , think 70 mph would be ok? dynoing isnt cheap around here so Id hate to loose money cause it didnt work <img border="0" title="" alt="[Mad]" src="gr_images/icons/mad.gif" />
Old Oct 22, 2002 | 11:11 AM
dand35th's Avatar
I was at the dyno a couple of days ago.. I had to run up to 70 mph then we started the run...so it wouldn't kick down..Anyway I would lock it from 70mph up..then your readings will be like 70-130mph...or whatever you rev to.
Old Jul 18, 2003 | 12:14 PM
Ed Blown Vert's Avatar
around 50 - 80 mph is fine for use on the dyno depending upon your gears. Dynoing on an unlocked high stall converter is just about worthless from a tuning perspective because the converter shift's extension does not allow you to tune the midrange and results in a skewed rpm &amp; torque readings.
Is it bad for the converter to lock it at WOT?
Old Jul 18, 2003 | 01:31 PM
ls1290's Avatar
Dumb Ass Vette Moderator
How did you install your switch?
