Mounting my new 3 BAR MAP
Old Mar 16, 2006 | 05:00 PM
anarchy99's Avatar
Default Mounting my new 3 BAR MAP
Hey guys, I've got my new 3 BAR MAP sensor, the one from MSD ignition out of summit racing. Anyways, it requires a different connector than the factory one has and it's freaking big so where do I mount the 3 bar map and how do I hook up the wiring to it? Any questions would be badass, since it's the last thing I need for my incon setup before I crank it!!!!
Old Mar 16, 2006 | 06:32 PM
dynocar's Avatar
Just take a razor blade or exacto knife and cut new slots in existing connector to match 3 bar map plug slots. Sensor A is sensor ground, B is vacuum/boost signal and C is +5V Ref.
Old Mar 16, 2006 | 06:41 PM
dynocar's Avatar
Oops, that razor blade/exacto thing wont work, I was thinking L98 engines. Go to a parts store and get a MAP sensor plug for a '91' F or Y body 5.7L for a 1 bar if a 3 bar is not available. Then you can do the cutting thing. A MAP sensor should be mounted level or higher then the plenum to prevent moisture drainage into it, as short of a vacuum/boost line as possible and do not "T" anything into that line for the best signal.
Old Mar 16, 2006 | 09:34 PM
anarchy99's Avatar
How do I mount the thing on the back of the intake though, since it's so big and it doesn't come with an orange little boot on it like the factory one. Do I hook it to a vaccum line and then connect it to the intake? Thanks for the input,and anything you guys can tell me would be badass!!!!
Old Oct 22, 2006 | 01:33 PM
smokinHawk's Avatar
bringing this thread back up. I see the C, B, A on my new 3 bar map.
but how do i tell which one is which on the stock map sensor or stock connector other then taking a multimeter and figureing it out that way, any one know the wirer colors?
Old Oct 22, 2006 | 01:42 PM
anarchy99's Avatar
I'd love to know the definite answer as well
Old Oct 22, 2006 | 03:48 PM
wait4me's Avatar
they both say abc, just hook a to a, b to b, and c to c.
Old Oct 22, 2006 | 04:35 PM
anarchy99's Avatar
this might seem like a stupid question, but if your running in SD without a MAF, what would the car run like if the 3 BAR MAP was hooked up wrong? I'm guessing like ****, but would it run real rich, or would it run at all?
Old Oct 22, 2006 | 06:33 PM
ozws6's Avatar
I'm getting ready to install a 3 bar map as well in a few weeks. I came accross this link http://hhscott.com/93tmv/3-bar_map.htm that has the breakout for the 3 bar map sensor wiring at the bottom of the page. As for the stock MAP sensor wiring, I'm curious about that as well.
Old Oct 22, 2006 | 07:17 PM
smokinHawk's Avatar
im looking at my stock sensor right now and there isnt an a, b or c
Old Oct 22, 2006 | 07:25 PM
wait4me's Avatar
It isnt in the label?
Old Oct 22, 2006 | 07:58 PM
anarchy99's Avatar
mine didn't have it either.
Old Oct 23, 2006 | 06:29 PM
smokinHawk's Avatar
nope not in the label, unless 2000+ had them on the sensor or something wierd like that.
Old Oct 30, 2006 | 09:05 PM
ozws6's Avatar
I got a copy of the GM service manual for an 01 F-body and the wiring diagram identifies the stock map wiring as follows:
A Tan Low Reference (ground)
B Lt Grn MAP Sensor Signal
C Gry 5v reference
Edited to include pic of connector.
