Yamabond and Quench Distance Questions
Yamabond is a liquid adhesive that takes up space. The paper work I was filling out got me to thinking as it requested the compressed head gasket thickness. Well, if you're adding a "thin" layer of yamabond to the surface between the heads and block isn't that going to affect my compression and quench? I was also wondering as to what people refered to as a, "thin" layer? Are we talking tenths, hundreths, thousandths?
Here's Forteen3GT's setup with yamabond. As you can notice some of it seeped out after being torqued down so that makes me think that a, "thin" layer isn't a negligable factor.
(Black stuff)
I tried searching on here and typing in yamabond only came up with 3 results. Any help would be greatly appreciated. Plus you actually get a thread that's worth being in this section vs somethings like how to identify a block, pick my heads, or a new two door blazer.
What I do know about it is from overhauling my kids motorcross bikes. I use it instead of using gaskets. Alot of motorcross engines do that. Also it stays semi wet. It is used and designed for use in areas of the engine that is in contact with fuel. Other sealents will disolve with consant contact with fuel. Other then that,,,, thats all the help I can be.
http://www.gmhightechperformance.com...kit/index.html
ESP co-owner and driver Ken Quartuccio said that since he started building nitrous LS1s in 2003, he has been going through head gaskets like crazy. After trying several different brands, his machinist suggested trying Yamabond (made by Yamaha), a form of sealant used by motorcycle engines in lieu of gaskets, to try and keep the heads from lifting. You can see the excess glue, which has been squished out between the head gasket and cylinder head at the corners.
***talk to the fellas at Eastside Performance***
Crazy as it may sound, it will actually let the cylinder head lift a little off the deck and keep the seal.
The Yamaha fellas use it in leau of head gaskets.... it seems to keep them from having leaky gaskets or something. So.... one would think that if the heads do lift..... this would assist by permitting you to keep from having to screw with blown or bad gaskets repeatedly.
Not too sure about using it as a head gasket, as rubber o-rings are used to seal the cooling passages between the cylinder and head, but there are no other gaskets used to seal the head to cylinder.
Atleast that is what I found out. Also...... smearing it with others peoples fingers after you squirt it out is always better than smearing it with your own.
Just my opinion....if you can lift a head you're going to blow the yamabond out.
If your buddy has had good luck since using it then he hasn't lifted a head yet.
