Prelim. 408 dyno results
Specs:
TH-400 trans( car set up for N2o )
6.0 block, 4.030
4.0 stroke
stage 3 6.0 heads (330 cfm)
solid roller cam set up for N20
ls6 intake
ported stock TB
These are just the prelim #'s, hopfully in the high 520's when done
Hopefully we will see a 6.0 block go in the 8's
No secrets here
12.5 comp and mid 600 lift. The engine peaked at 6500 rpm. Sometimes you just hate to dyno Auto's with no lock up and post numbers as they don't seem very impressive but we are happy as we had a similar NA setup that made a bit more power and ran 9.60's NA
Time passing and R&D sure pays off, smaller portvolumes, attention to detail and programming sure make the diff.
The car will get sorted out at the track first NA and then it will get sprayed
No secrets here
You can PM me if there is other information required
