Prelim. 408 dyno results
Just sharing some info from a 408 we had on the dyno today. 515 rwhp and a converter flash over 600rwtq.
Specs:
TH-400 trans( car set up for N2o )
6.0 block, 4.030
4.0 stroke
stage 3 6.0 heads (330 cfm)
solid roller cam set up for N20
ls6 intake
ported stock TB
These are just the prelim #'s, hopfully in the high 520's when done
Hopefully we will see a 6.0 block go in the 8's
Specs:
6.0 block, 4.030
4.0 stroke
ls6 intake
ported stock TB
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
![Cheers!!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cheers.gif)
Originally Posted by FASTONE
Great numbers,I bet that car will be fast!! How much compression and whats your valve lift???Ballparks OK!!
Time passing and R&D sure pays off, smaller portvolumes, attention to detail and programming sure make the diff.
Thanks Nick, sounds great I'm building a 408 ironblock just for the track{1/8mile mostly,we don't have a1/4 close by]want to use a big solid roller cam probably around 260 @.050 with .670 lift ,110LDA??tThinking of using ported 5.3,s Jesel shaft rockers 1.8 rr, maybe aluminum con. rods, electric w.pump ,fabricated aluminum intake,not sure on pistons yet maybe Diamond or C .P. What do you suggest? BY THE WAY I LOVE ALL THE WORK I'VE SEEN OR READ ABOUT FROM YOUR SHOP!! Thanks Mark.
Thanks Nick, you must think I might have trouble with the 1.8 Jesel, I will be running some big springs ,I'll lose about.037 lift but I guess that'll be OK,should be about.636 with 1.7's.You think I should run more duration,they have 268, 264, 260, all with the same lift? This is going in a gutted car 2500lbs 4-link rear,. 4.88 gears 4500-5000 stall with a powerglide ,plan to run 2 stage no2 after I get the motor sorted out.probably will see 7500-8000RPM.
Originally Posted by 1fstTA
NIck did you guys spray the car on the dyno at all.
![Cry](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cry.gif)
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Originally Posted by ITSovr4U
What was the exact lift and the LSA and CL on that cam if you dont mind me asking.
![Rolleyes](https://ls1tech.com/forums/images/smilies/LS1Tech/rolleyes.gif)
You can PM me if there is other information required
I just wanted to say thank you to ARE for doing a great job on my 30th. hope to see great #'s out of her!! also wanted to say that nick and his crew are getting thing back in swing at ARE and should be back on track real soon!! nick is focusing his efforts on customer service and helping people out. it will be a rebuilding year for ARE and i hope to see them at some of the events during the year!! good luck ARE and thank you again, bill
