Code P1416 & P1637 How to Fix?
Old May 25, 2009 | 07:32 PM
Pro Mouse's Avatar
Default Code P1416 & P1637 How to Fix?
I just bought my wife a 99 Trans Am ,Getting Codes,HP Tuners says P1416 Secondary Air Injection (AIR)System Bank 2 and P1637 Generator L-Terminal circuit. How do I fix these and are they any thing to worry about?
Thanks For the Help....
Old May 25, 2009 | 08:06 PM
Mike454SS's Avatar
P1416 is nothing big...easiest way to "fix" it is remove the AIR system from the car, and turn the codes for it off.
P1637 though is the alternator...possibly some damage to it's wiring, or possibly something wrong with the alternator, or it could be the wrong alternator for the car.
Old May 25, 2009 | 08:24 PM
Pro Mouse's Avatar
Thanks Mike,This car has some kind of black box hooked up to the TB going to the Alternator?I haven't a clue as to what it is....
Old May 27, 2009 | 10:04 PM
Mike454SS's Avatar
Sounds like something aftermarket...I'd look into removing it and then seeing if the P1637 stays off when you clear it (but keep it enabled).
Old Nov 17, 2010 | 04:46 PM
WS6 Rampage's Avatar
From: The dirty taint of the country. ...Los Angeles
God Damit!!! I'm just threw this code and my alternator I guess is the culprit!
Old Nov 17, 2010 | 04:59 PM
2001NBMZ28's Avatar
Check the exciter (red) wire/connection at the alternator. Also check the voltage at the battery with the car off and running.
Old Nov 18, 2010 | 12:40 PM
... Does that wire have a habit of comming loose?
Old Nov 19, 2010 | 04:26 AM
BTW, how much is the wire?
Old Nov 19, 2010 | 05:47 AM
Asian LSX's Avatar
I found this on ebay the other day.
http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWAX%3AIT
Old Nov 19, 2010 | 02:11 PM
Cool. That actually helps. Thanks!
Old Nov 20, 2010 | 04:25 AM
BTW,.. Just a bit more info on my issue. (P1637 code) ... Battery has a charge. All the lights for the gauge cluster still light up, alarm works & headlamps raise and lower at normal speed. .... I can't hear the starter 'click' when I turn the key. .... Starter Fuse isn't blown... SHE JUST WON'T START!
Old Nov 20, 2010 | 08:28 PM
Update: ... Removed the alternator and battery today. Took them to Autozone for testing. Both in good shape. Went down to the dealer, bought an exciter wire ($54.40!!!) and cut and spliced it in.... CAR STILL WON'T START!!! ... Still throwing the same damn code too (P1637) ... God Damit!!!!
Old Nov 22, 2010 | 06:20 PM
Anyone?!! ... I need help so if anyone can throw their .02 cents in I'd greatly appreciate it.
Old Nov 26, 2010 | 05:04 PM
ls1fag's Avatar
The Duratester at AutoZone will not test the L Circuit wire if I understand how the L Circuit works correctly. I would advise you to buy the AutoZone alternator put it in, see if it works and if the code comes back simply pull the alternator clean it and return it. As far as it seems that shouldn't keep it from starting?
http://www.gearchatter.com/viewpost14190.php
Old Nov 27, 2010 | 11:52 AM
SmokingWS6's Avatar
If your battery has a full charge, the alternator code will have nothing to do with it not starting.
