Generation V Internal Engine 2013-20xx LT1
New LT1 for 2014 6.2l alum block
Old Dec 14, 2012 | 12:00 PM
  #441
Bigg_Gunz's Avatar
Final got a small amount of GO ahead to explain VVT in the 2014 LT1. So lets get into and I will try to answer all the other questions in my pm's and on the thread in this answer as well
Variable cam timing is a means of precisely controlling the flow of air into and out of an engine by allowing the camshaft to be dynamically phased relative to its crankshaft. This is the water down version "RED TAPE" on extremely accurate details... so to put it simply these are the typical inputs systems are....
Engine Valve Timing systems = ignition systems etc.
Timing Chain Itself = chains are the best solution for timing drives due to compact packaging, optimized efficiency, the ability to minimize dynamic instability, proven long-term field durability and adaptability across multiple engine models.
Variable Cam Timing = ECM and Crankshaft Position data
The phaser = OVC AND OTHER SYSTEMS
Secondary Air systems = PCV VACUUM PUMPS
Actuators = TOP SECRET
Thermal Management components and systems = Enormous amounts of data inputs from sensors. This combats Heat Energy vs Load. And this is some what complex but it dealing with exhaust loss, cooling loss, pumping loss, and mechanical frictional loss.
Then throw in complicated transmission controls and this quickly becomes overwhelming to deal with not to mention the ABS and STABILITY SYSTEMS all functioning as one.
And this is not everything out there yet. No offence to anyone but there are many things that have not been tried yet by the aftermarket. A lot of things I had to leave out due to "RED TAPE."
This is the truth, this is NO reason to be cocky or snuff, this is just a pure simple fact. I am here to answer your questions...There is no such thing as just tuning anymore dealing with VVT, VVC, DI, CVVT + DI or CVVT +VVC + DI + FORCE INDUCTION. There is a few million dominos in the equations/ variables and all it takes is just one domino to change everything.
Then throw in Direct Injection and it really becomes an area you have to have to be some type of expert/guru..
Understanding
What will make the VVT problematic for most...... is the ECM is working serious mathematical equations to make the cam think the intake side of the valves are constantly changing the timing to stay open different durations for optimal a/f ratio configuration.
In reality it's NOT, In VVT the Duration or Lift is not changed, just the timing in VVT. It doesn't matter because it's what the pressures are telling the ECM and this is where VCCT is slightly more complicated as we've given the cam more free range of motion/timing. And that is putting it lightly and watering it down. And yes guys this is all still dealing with just "valve overlap" at the moment, but I will get into that later.
Now in VVC all the cam spec parameters are changing constantly and to deal with this you have to a detail understanding of all systems you have to be a subject matter expert no question about it. You will see this in the LARGER MORE POWERFUL VERSION of the 2014 LT1. Which will have the CAM in CAM system, this is extremely complex as they're are cam phasing, cam lobe switching, and true variable duration.
Variable duration has more effect on power than opening and closing the valve earlier or later as with normal cam phasing cycles aka CVVT/VVT.
This is where the ECM in the 2014 LT1 comes into play. Think of it as a jury of experts engineers from all fields of all systems over the vehicle, receiving data & voting on what outputs are appropriate in nano seconds. Think of the first OS system as a BOARD OF DIRECTORS ...they are free to do as they please as long as the sensors are reporting accurate information/data. However if they get to radical the Second OS steps in to prevent a total destruction of the engine/system/vehicle with the proven stability parameters not marginal stable parameters.
The engine is very advanced, the ECM is highly intelligent when it comes to making decisions based on input data. The engine is slightly and almost at the limits of stable combustion.... Don't panic this does NOT mean it is nearly maxed out in horsepower. It just means modifying the combustion cycle beyond physics is foolish. So what happens? So what Next? A dual mode ECM with even more exotic variables forget about 100's of coefficient models think thousands of engine operating models. The ECM is self aware and can choose what is best your laptop and tuning is NOT needed.
The ECM can and will control VVT to increase valve overlap to the point where the engine can pump air with no load this is done for reasons that I am NOT at liberty to say. When in performance mode and at WOT open throttle while the exhaust valve is open the ECM is will send a bursts of fuel down into the exhaust system this creates a controlled explosion in the exhaust system and this is done for reasons I can't state and will NOT elaborate more on. So DO NOT ASK....
When the average gear head looks at the 2014 LT1 cam specs. He thinks emission cam / gas saver cam and relatively conservative. And those specs are 200intake/207exhaust duration LSA 116.5 ........cam lift intake.551 and exhaust .524
The first thing that person wants to do, due to habit is change the cam for something larger... more aggressive then change the timing and install larger injectors to dump fuel into the cylinders. That works for yesterday's technology and when doing this in these types of engines this is inexperience... what use to work in past engines DOESN"T work in these engines. This is NOT your engine of yesterday. This engine platform is capable of making monstrous horsepower in OEM form. Experience pending of course.... You have to go back to school or enroll in some type of semester course within the technology developers to get a handle on what is happening today.
People will say.... Hey Direct injection has been around a very long time and VVT has been around a very long time... why is it all of a sudden so special/different? It is all about precision and the ultra fine control today's processors will ALLOW for mass production. The ECM allows for more efficiency due to greater processing of equations and variables which allows for greater efficiency/horsepower.
This so called gas saver cam your looking at can do crazy things with extreme valve overlap in performance mode for racing without even touching a control of a laptop. The ECM 92 controller can quickly modify itself to each and every single one RPM in the powerband with extreme precison. We are talking individual RPM, Throttle Inputs, Cam inputs, crankshaft inputs, fuel tables, fuel pressure solenoid and all other systems etc.... they are constantly changing. The ECM 92 is super clever & self aware and combined with this cam will out perform much larger cams, I am 100% sure of it. This is possible due to the complex physics at work in the engine.
What you call emissions standards is what we call captured efficiency. What is emission? Simply put it is wasted potential horsepower....... Everyone is so concern and getting caught up with losing HP/TQ due to the drivetrain drag. That they over look the fact of the matter is most highly modified engines throw away the possible 15%- 20% of dynamic cylinder pressure/ HorsePower into the exhaust system due to excessive inefficiency cams and cylinder head combinations. There is a lot to be gain here.
Then that person spends $1000.00 of dollars changing more parts for more... HP/Cylinder Dynamic Pressure threw cam swaps, intakes, heads.... All your doing is chasing efficiency... and most give up when seeing peak numbers that look impressive and after a while...that horsepower number becomes numb and boring...then is on to repeat the process of changing more parts to raise horsepower....
And the difference is..... Efficiency is combining your parts in a systematic order. And Effectiveness is doing the right thing so that the parts will do their very best.
And if that is hard to understand ..... what that means is .... selective the parts to do the combustion process is just as important as the quality of the process and the parts being used. Optimization is key each and everytime.....
I stated on 12/04/2012 post #350 that GM was going to make a major announcement. However it was delayed until yesterday. And everyone is asking me about the 4.3, 5.3 and 6.2 liter engines in the pm's. Guys you know that I am not at liberty to disclose official output numbers. Please understand that I am here to address your question without over walking the tight rope.
What I can tell you is this.... the 4.3liter V6 engine will out perform a stock LS1 in every area possible. Or to say it another way it will drag the STOCK LS1 ***** against the Asphalt. That should give you some type of gaming changing performance we are looking at going forward.
Bigg Gunz
Old Dec 14, 2012 | 12:06 PM
  #442
WarShrike's Avatar
Hey Bigg_Gunz, a little deviation from this but can you confirm something for me? I'm not really on the V8 stuff, but more active in the V6 areas. One of the guys noticed in a video on the new Silverado that it has a 4.3 V6 option, and said it looks strikingly similar in design to the new LTx platform.
Is it based on the new LTx block and does it have the same cylinder head characteristics or is it just another standalone V6?
Edit: Just read the last paragraph of your post above. Holy ****.
Old Dec 14, 2012 | 12:30 PM
  #443
jrob56's Avatar
Awesome read, I cant wait for the official announcement! Hopefully then BG's hands will be slightly less tied and he can fill us in even more then on what GM might leave out of the press releases.
I know there has been some hostility in here, why exactly I am not sure. I never took his statements to be that arrogant and since most here Know nothing about what hes talking about mainly this ECM Id say its best to wait and see. I for one am excited and thank you BG for sharing what you can with us.
Old Dec 14, 2012 | 01:08 PM
  #444
josh12886's Avatar
Bigg Gunz, Is this engine going to have the carbon build up issues that plague so many DI engines?
Old Dec 14, 2012 | 01:14 PM
  #445
Justin@GMHTP's Avatar
LS1Tech Sponsor
WarShrike,
The new 4.3-liter V-6 is essentially an LT1 (well, more like an L83) with two cylinders cut off. It will feature VVT, AFM, and Direct Injection. 3.92-inch bore, 3.62-inch stroke... 11:1 compression, all-aluminum. Many (if not almost all) of the Gen 5 is in the new LV3 V-6.
Old Dec 14, 2012 | 02:27 PM
  #446
SBC_and_a_stick's Avatar
Will the version 2 vary lift?
What will be the general gains going from version 1 LT1 to version 2?
By "Larger and more powerful" I take it to be in N/A form. Will the larger version 2 be offered without forced induction?
Old Dec 14, 2012 | 03:10 PM
  #447
Cphelps's Avatar
Bigg Gunz,
Thanks for all of this information!
http://www.autoobserver.com/2011/06/...-adopters.html
None of GM's other current DI engines suffer form that problem, no reason to think the Gen V engines will, either.
Old Dec 14, 2012 | 03:14 PM
  #448
Wnts2Go10O's Avatar
so the other engine will use the Vipers cam setup?
Old Dec 14, 2012 | 04:32 PM
  #449
disc0monkey's Avatar
Originally Posted by Bigg_Gunz
[B][COLOR="Green"]What I can tell you is this.... the 4.3liter V6 engine will out perform a stock LS1 in every area possible. Or to say it another way it will drag the STOCK LS1 ***** against the Asphalt. That should give you some type of gaming changing performance we are looking at going forward.
Bigg Gunz
Ah ****. but anyway, that sounds pretty awesome. wouldn't mind the camaro with these new engines.
Old Dec 14, 2012 | 04:44 PM
  #450
ringram's Avatar
Id like to see how variable duration works. Perhaps via variable lift?
Im stuck between a viper and the new C7. So definitely interested in the new engine tech.
I suspect there is nothing new to see, but a well rolled together package. Afterall BMW, Merc, Audi etc have had fancy valvetrains for years.
I wait with baited breath anyway
Old Dec 14, 2012 | 05:07 PM
  #451
Snkebait95's Avatar
That sounds awesome. Im going to start saving for a c7 now! Im anxious to hear why the engine sends fuel down the exhaust to create a controlled combustion.
Old Dec 14, 2012 | 05:11 PM
  #452
Area47's Avatar
Originally Posted by Cphelps
Bigg Gunz,
lol
yes they do. check out the lnf issues in the cobalt ss.
Old Dec 14, 2012 | 09:09 PM
  #453
texel's Avatar
A shot of fuel down the exhaust would sure spin up a turbo fast....Cheers
Old Dec 14, 2012 | 10:03 PM
  #454
Cphelps's Avatar
Originally Posted by Area47
lol
I will have to check into that then. I had never heard about the LNF having any issues like that, but I haven't followed those as closely as the V8 stuff, so I must have missed it. Thanks for the info.
Old Dec 14, 2012 | 11:14 PM
  #455
texel's Avatar
"What I can tell you is this.... the 4.3liter V6 engine will out perform a stock LS1 in every area possible. Or to say it another way it will drag the STOCK LS1 ***** against the Asphalt. That should give you some type of gaming changing performance we are looking at going forward. "
So the new 6.2 Liter V8 then makes at least 1.44 x 350 HP or 504 HP Sweet !
Old Dec 15, 2012 | 12:54 AM
  #456
Burrhos's Avatar
Bigg Gunz,
Can you confirm or deny that the LT1 has active EGT monitoring? I didn't see any leads in the manifold on the release pictures from GM. Are they hidden somewhere or not a part of the E92 tuning?
Old Dec 15, 2012 | 01:04 AM
  #457
Nick V.'s Avatar
im not liking that this new v6 maybe put my ls1 to shame. but i suppose all good things come to an end. i hope its a different story on the streets though
Old Dec 15, 2012 | 11:14 AM
  #458
ChucksZ06's Avatar
I would not be too worried about that Nick. These new engines will be great but that Big Gunz guy is a little full of it at the very best. He is like a good con man...enough truth to set the hook mixed in with BS.
Old Dec 15, 2012 | 12:12 PM
  #459
Bigg_Gunz's Avatar
The 2014 LT1 ENGINE and others have a PCV + Vacuum PUMP that will eliminate the carbon build up issues that were previously problematic.
Bigg Gunz
Old Dec 15, 2012 | 12:19 PM
  #460
Bigg_Gunz's Avatar
Start saving for the C6 z06 replacement.
Bigg Gunz
