ABS INOP, PARK BRAKE, and TCS OFF lights come on at same time. WTF?
When I scanned it, it threw the code C0550 something EBCM malfunction so I replaced the EBCM only (I got the whole ABS module used from this forum for USD 30).
I think all LS1 F-body years (1998-2002) are compatible and regardless camaro or firebird.
I put in a 2000 T/A's EBCM on my 2001 Z28 and is working fine. Just make sure whether yours is a 3 or 4 channel as well as the one you are getting.
Manufacturer: AC Delco
UPC: 707773298091
P/N 12457657 - Electronic Brake Control Module Kit
$620.75
& C0896 Out Of Range Voltage At The EBTCM Probable Causes; Charging system fault, Open or short circuit condition, Poor electrical connection, Failed relay condition, Ignition switch fault.
I'm the original owner and I'm at 137,000 miles. I have had the above codes come on and off for a couple of months, and have since replaced the front wheel hub assembly's that included wheel sensors, replaced alternator, and "just" cleaned the rear sensors for the first time, one had a strand of wire stuck to it (wire not in photo below).
Cleared codes, I'll have to drive it for about a week and see if codes come back, hopefully it was just the dirty rear sensors.
ABS Trouble Code Search
http://www.wellsve.com/custom_search...45&Submit.y=18
2000 F-Body DTC's
http://www.gearchatter.com/viewforum36.php
I finally invested in a OBDII/ABS Scanner. I've been having the same issues. Randomly having the BRAKE/ABS INOP/ACR OFF lights come on at the same time. I'm unable to pin point when it happens or how to make it happen other then waiting for it to just randomly come on. I pulled these codes:
C0550, C0896, P0500
The picture you submitted is that the wheel speed sensors? Any Idea what might be my issue?
C0550, C0896, P0500
You can still drive while the abs module is being repaired.
Best find ever! I was looking at 1,300 for repair and fixed under 125.00!
They show you how to take apart the module to send in for repair. 4 screws in 10 minutes and its off..
CheapABS.com
Also had my wives GTP fixed too.
Later
CheapABS.com
Later
UPC: 707773298091
$620.75
ACDelco 12457657 Control Module Kit
by ACDelco
Be the first to review this item
Price: $690.00 + $2.99 shipping
In stock.
Usually ships within 2 to 3 days.
Ships from and sold by AC-Direct.
Note: ACDelco partners with other manufacturers to supply the parts your car was originally built with. This product is in a ACDelco package, however the part may have been manufactured by an independent ACDelco supplier and could have a different color or shape than the product image above.
$668 rockauto.com
