Old 04-10-2016, 09:53 PM
  #321
lsxlowtech's Avatar
Super nice build. Sure takes a lot of time! The car is very cool.
Old 04-11-2016, 04:29 AM
  #322
franktf's Avatar
Thanks..... Yes it does, it would get done sooner but I only work on it Sat and Sun mornings.....
Old 04-12-2016, 12:56 AM
  #323
BLKMGK's Avatar
Love this build!
Old 04-15-2016, 08:08 PM
  #324
franktf's Avatar
Originally Posted by BLKMGK
Love this build!
Thanks.....
Old 04-15-2016, 08:12 PM
  #325
franktf's Avatar
Got all my powder coated suspension/brackets and ceramic coated hot side stuff back this week..... I also picked up a bunch of an hose and fittings to get started plumbing next week after I get the front end painted this weekend.....
Old 04-16-2016, 04:02 PM
  #326
franktf's Avatar
Today I finished prepping the front end for paint, masked it up and got it painted with POR15 paint..... Tomorrow I will get a couple coats of Chassis coat on it and texture it.....
All masked up and ready to paint.....
2 coats of POR15 applied.....
Old 04-17-2016, 12:35 PM
  #327
franktf's Avatar
Got it painted and textured with Chassis Coat today.....
Here is what the POR15 looked like this morning after drying over night(it is semi gloss).....
and here it is after textured Chassis Coat(last one is a closer look at the textured finish).....
Old 04-17-2016, 01:04 PM
  #328
Project GatTagO's Avatar
Received 1,442 Likes on 910 Posts
Looking sweet Frank!
Andrew
Old 04-17-2016, 02:00 PM
  #329
franktf's Avatar
Andrew
Thanks.....
Old 04-17-2016, 08:30 PM
  #330
franktf's Avatar
I went down to the shop and unmasked it after the Nascar race was over..... It's looking really good..... It was dry to the touch but not completely dry yet.....
It is quite a bit darker then the firewall that was painted with the same paint a little over a year ago..... I think it will look fine once the rest of the paint dries and gets a little age on it, I think the firewall will also darken up a little if I clean it real well.....
Here you can see the difference in them.....
Old 04-20-2016, 08:27 AM
  #331
aggie91's Avatar
Did you spray or brush on the POR15? the end results look great!
Old 04-20-2016, 11:14 AM
  #332
Jimbo1367's Avatar
Great vision. I love it.
Old 04-20-2016, 03:57 PM
  #333
franktf's Avatar
Thanks, sprayed and textured.....
Thanks.....
Old 04-23-2016, 02:27 PM
  #334
franktf's Avatar
Today I put all the bulkhead fittings in the front of the car..... Then I made the stainless trans cooler hard lines that go in the outer fenderwell from the core support to the back of the tower on the driver side..... Next I made the stainless brake line that goes from the engine compartment bulkhead down to the union on the side of the front subframe..... Last thing I got the fuel feed and return braided hoses routed through the torque box to the bulkheads in the front of the driver side tower.....
Here's the trans cooler hard lines, you can also see what I got done on the fuel lines today(still need to get the retainers on and finish routing them to the rear)..........
Here's the brake line.....
Old 04-23-2016, 05:25 PM
  #335
Fahrenschnell's Avatar
Damn fine work.
Old 04-23-2016, 09:07 PM
  #336
franktf's Avatar
Originally Posted by Fahrenschnell
Damn fine work.
Thanks.....
Old 04-24-2016, 03:40 PM
  #337
franktf's Avatar
Got a little more done today..... Modified some Billet Specialties hose separators so I can use them for hose retainers, put 2 on in the inner fender area using riv-nuts to hold them..... I put a couple vinyl lined clamps on the trans cooler hard lines..... I also put the motor mount bushings in the k-member and bolted it in the car..... Then I put the car up in the air a little higher so I can get the fuel lines attached to the underside next weekend.....
Here is todays progress.....
Old 04-26-2016, 02:42 PM
  #338
static low 92's Avatar
I really enjoy the creativity and thought put into incorporating bulk heads etc into car. Makes for very clean install.
Keep up nice work sir
Old 04-26-2016, 03:10 PM
  #339
Motoboy's Avatar
Great looking project. Really like your attention to detail.
Old 04-26-2016, 09:26 PM
  #340
franktf's Avatar
Glad you like it and thanks.....
Thanks.....
