Aluminum 441 build on corn
Old 04-10-2016, 08:13 PM
  #41
DavidBoren's Avatar
What cam did you end up with? I'm glad to see progress on this.
Old 04-11-2016, 01:43 PM
  #42
BennyB's Avatar
Ended up with a custom ground cam from Martin Smallwood
Old 04-11-2016, 04:40 PM
  #43
"I MAID THEESE"
Mavn's Avatar
Specs on the Cam..?
Old 04-11-2016, 08:13 PM
  #44
BennyB's Avatar
Originally Posted by Mavn
Specs on the Cam..?
ill find the cam sheet and post it, but its 25x/ 26x .6xx/ .6xx on a 115+5
thats just off the top of my head ill find the cam sheet and post it in a later post along with some more pics getting the cam, oil pump, timing set and covers on it.
Old 04-12-2016, 12:27 AM
  #45
gnx7's Avatar
what oil pump are you going with? And Tchain?
Old 04-12-2016, 09:06 PM
  #46
BennyB's Avatar
JP double roller timing set and slp oil pump since its already clearenced for a double roller
Old 04-26-2016, 08:57 PM
  #47
BennyB's Avatar
Lot of grinding to get the front cover to fit with the jp double roller and slp oil pump
Old 04-26-2016, 08:58 PM
  #48
BennyB's Avatar
Old 04-26-2016, 09:44 PM
  #49
DavidBoren's Avatar
Oh, that's pretty.
Any reason you went with the high pressure pump instead of a high volume pump? Just curious.
Old 04-27-2016, 04:00 PM
  #50
BennyB's Avatar
Originally Posted by DavidBoren
Oh, that's pretty.
Thanks man. I've always ran slp oil pumps so I just used what slp offered
Old 04-27-2016, 05:20 PM
  #51
BennyB's Avatar
Does that look right for the damper/ pulley. I might have to get a measurement and see or install the alt. and see if things line up.
Old 05-09-2016, 07:18 PM
  #52
BennyB's Avatar
Test fitting the Windage tray, oil pump pickup tube and oil pan. Had to bend the pickup tube to get right over 1/4" clearance from the bottom of the pan. The Windage tray ended up taking 3 washers under it and the bfh method ��
Old 05-09-2016, 07:21 PM
  #53
BennyB's Avatar
Clay from measuring pickup to pan clearance. I ended up at a little over 1/4" measuring the thinnest section of clay
Old 05-09-2016, 07:24 PM
  #54
BennyB's Avatar
Pan ready to go on. Grease on the rod bolts from when I was making sure the rods weren't going to hit the pan. I had to check with the oil pan gasket on, but no grease was rubbed off when I checked so I should have sufficient clearance. Ultra black sealant on all 4 corners right before I dropped the pan on
Old 05-09-2016, 07:27 PM
  #55
BennyB's Avatar
Oil pan is on and torqued to spec. I think that's good for now time to call it a night.
Old 05-09-2016, 08:10 PM
  #56
DavidBoren's Avatar
Lovin' it, man. This thing is going to be such a monster.
Old 05-09-2016, 10:43 PM
  #57
KCS
KCS's Avatar
It warms my heart to see people check the little (but critical) details like pan to pickup clearance. Good job.
Old 05-10-2016, 09:46 PM
  #58
BennyB's Avatar
Thank you guys for the kind words. I try my best to pay close attention to detail
Old 05-11-2016, 03:27 PM
  #59
"I MAID THEESE"
Mavn's Avatar
Moar pics
Old 05-11-2016, 07:28 PM
  #60
BennyB's Avatar
Moar pics
Fun stuff! Not really... Going through the 15 year old wiring harness and cleaning it up
Looks like the damper is fully seated and lines up with the alternator after bolting it up
Quick Reply: Aluminum 441 build on corn
