Engine Build - Going Turblowed
Old 04-01-2016, 12:44 PM
  #161
dt23400's Avatar
any pics of your spark plug wires on how you ran those. thats my next step in my car.
Old 04-02-2016, 11:48 PM
  #162
JordanRN's Avatar
Basically all I did was use the LT1 wire set and make sure none of them touched the manifolds. The boots are the 90* ones and they're all facing down. I'll take some in the AM if I remember.
Old 04-03-2016, 10:04 PM
  #163
Serioussn95's Avatar
Great thread man. from the video it looks like your using Tracy Grimm at speedfab. I will be using him as well to tune my Forged 370/S480 th400 mustang. That guy has done an amazing job with kyles car. Im in Daytona so the drive is well worth it to use him to tune my car. Goodluck with the rest of the build man.
Old 04-05-2016, 10:50 PM
  #164
JordanRN's Avatar
Tracy's a good dude for sure.
Little but serious update on progress.
Ditching the TH400 idea for the 4L80e set up since i have the core already. Transbrake, billet internals, all the goodies.
Drag Pack Setup Ordered
Ford 9" ordered
Old 04-07-2016, 05:20 PM
  #165
JordanRN's Avatar
Few packages showed up today...
Old 04-08-2016, 05:51 PM
  #166
JordanRN's Avatar
HPTuners came in, Crossmember for 4L80E came in and had wheels/tires mounted and balanced.
Old 04-15-2016, 02:36 PM
  #167
JordanRN's Avatar
So I did a thing...
Anyone want to buy a turbo kit, gently used? Haha
Old 04-22-2016, 03:41 PM
  #168
JordanRN's Avatar
Hotside is installed, some of cold side is. Weather didn't want to cooperate.
110% recommend Huron's products, install was a breeze so far for a one man operation.
Old 04-25-2016, 03:23 PM
  #169
jamescallowa's Avatar
Great post !
Old 04-25-2016, 04:26 PM
  #170
"I MAID THEESE"
Mavn's Avatar
Cant wait to see it finished!
Old 04-29-2016, 03:08 PM
  #171
dave04da's Avatar
Dyno results in. 391 hp 391 tq.
Old 05-02-2016, 07:41 PM
  #172
JordanRN's Avatar
Some updates....
Not everyone found the downpipe straight up funny, someone said Curtis ruined it for the rest of us...
Good thing i have a bump exit one I'll be installing.
Old 05-14-2016, 02:46 PM
  #173
JordanRN's Avatar
Had a bung welded for the screw in IAT and fixed fan wiring up.
First Maiden Voyage last night to a local meet. The hood on the car is warped on one side so I figured why not cut it, hahah.
Old 05-18-2016, 11:23 PM
  #174
JordanRN's Avatar
Just some information for what it's worth.. Alternator Relocation Bracket by Hawks Third Gen requires a CS130 style alternator.
Two Derale 16925's, One Racetronix 340LPH Pump, One Scavenge Pump will pull enough amps at idle to cause issues. Fighting a charging issue even with driving.
Alternator is a CS130, running with just the scavenge pump on the voltage was 13.45.
When the first fan turned on, it dropped to 13.21 and then when the second fan came on, it dropped it to 12.67.
Ordered a Powermaster Street Alternator 57861 which puts out 140amps, where as stock LS alternators are 102amps and CS130's are 105amps. Hopefully this resolves my issue.
Old 05-24-2016, 08:45 PM
  #175
JordanRN's Avatar
Jakes D3 transbrake, 300MM Input Shaft and Rollerized Front Hub! Trans guy is building it tomorrow and I'll be ordering the PTC 9.5 Non-lockup converter tomorrow as well.
Old 06-05-2016, 02:04 PM
  #176
JordanRN's Avatar
Drove the car to the tuner's shop yesterday, had a nasty oil leak from hell that I could not figure out. Turned out to be my catch can causing too much crankcase pressure. (Duh move on my part) Once we removed it, the oil leak stopped.
Had one of my friends fab me up a bumper exit exhaust instead of the scuba steve snorkel too.
The results are in for the 7# wastegate spring...
470 to the wheels and 496 torque. Was hoping to break 500 but being that it's only 6lbs, I'll take it. This is on a completely stock 4L60E and stock 10bolt.
On my way home one of the trans lines decided it wanted to pop out of its fitting somehow... Needless to say, I wasn't a happy camper. Just drove it around the block few minutes ago and it seems to be fine.
Old 06-10-2016, 10:19 PM
  #177
JordanRN's Avatar
Gave her a quick clean and spray wax after i put the old hood back on. Just need to get the front bumper cut out and put it back on.
Old 06-11-2016, 11:01 AM
  #178
A.R. Shale Targa's Avatar
Getting pretty close there. Makes good power on low boost
Old 06-11-2016, 12:48 PM
  #179
JordanRN's Avatar
Thanks, currently waiting on the converter and trans to show up so I can put the rest of the goodies in. Then it will get turned up on e85 to make the serious power.
Was out Wednesday night and one of the fuel pumps decided to die, luckily I had the access port cut so we were able to get to it with ease. Brand new pump too, wonder if Racetronix will warranty it.
Old 06-12-2016, 09:25 PM
  #180
booogs's Avatar
what kind of numbers are you expecting with the new kit and e85? also what boost are you at right now? with all due respect, 391hp is pretty good but i thought the numbers would be a bit higher tbh.
Quick Reply: Engine Build - Going Turblowed
