Old Jul 23, 2016 | 05:18 PM
  #441
franktf's Avatar
Today I marked up the hood/fenders and got the rest of the dzus brackets mounted to the fenders..... Then I put the front fender support brackets, bumper brackets, inner fender plastics and lower rocker trim on the car.....
This week I got a Holley single plane intake, fuel rails, Edelbrock elbow and some ARP hardware for it..... I got all this stuff out of the boxes and mocked it up in place, my plan is to use the stock ported throttle body I have(we shall see)..... This set up fits my application much better then the stock LS1 intake, at least for my liking..... I will have to make a new Monte Carlo bar for this set up(no big deal)..... The only other problem I have is the back of the pass side fuel rail is a little close to the heater core fitting coming out of the firewall..... Probably not a problem, just closer then I like..... I have done some research on injectors today and the LS7 style injectors will gain me 1" of clearance on that fitting which will make me much happier(I may have to make this change.....
Here's the progress.....
Old Jul 23, 2016 | 05:45 PM
  #442
RattyMav's Avatar
Easily my new favorite Comet/Maverick build. Love your attention to detail! I sold my Maverick not too long ago, definitely regret it... Keep up the good work, man
Old Jul 23, 2016 | 07:46 PM
  #443
franktf's Avatar
Thanks..... Time to get a new one.....
Old Jul 24, 2016 | 07:35 AM
  #444
speedtigger's Avatar
Old School Heavy
A few Mav's for you. Not sure where this is, but it just showed up in my Facebook feed.
Old Jul 24, 2016 | 01:51 PM
  #445
franktf's Avatar
Got to be from either the MCG gathering in Ohio of the MCCI Roundup in Penn, both were this month.....
Old Jul 24, 2016 | 03:16 PM
  #446
franktf's Avatar
I set the hood back on it this morning just to make sure everything had good clearance, which it did..... I am just going to use the Holley fuel injectors I have, I was able to figure out a little better routing for the hoses/fittings that I am happy with..... I took everything back off and boxed it up for the moment..... I removed the valley cover so I could mount the coolant block I previously made, I could even use the stainless lines I made before but I think I will make some new lower ones anyways..... I will get the cover and block cleaned up and repainted this week..... I also figured out where I want to put the fuel pressure regulator so I will get a bracket made for it this week too.....
Here's a pick of the car sitting on the ground with the hood on it from this morning.....
Old Jul 30, 2016 | 03:34 PM
  #447
franktf's Avatar
Got the valley cover assy cleaned up, blasted and painted this week..... I put it back on this morning along with the knock sensors/wiring..... I also made a bracket to mount the fuel pressure regulator this week and got that on too..... I put the fittings all in for the steam ports, made and installed the rear 2 stainless hard lines.....
Old Jul 30, 2016 | 03:49 PM
  #448
Old School Heavy
Its not too late to put a nice 5 angle valve job on there... Just sayin'.
Old Jul 30, 2016 | 04:18 PM
  #449
Project GatTagO's Avatar
I think this is all "proof of concept." I bet there is a future short block and other engine mods planned.
Andrew
Old Jul 30, 2016 | 04:35 PM
  #450
franktf's Avatar
I hand lapped the valves to verify seats when I ported the heads..... No five angle needed at this time..... I just need to get the damn thing running.....
Andrew
Not at this time.....
Old Jul 30, 2016 | 04:42 PM
  #451
Neither was EFI, and look at ya now :-)
Andrew
Old Jul 31, 2016 | 04:10 PM
  #452
franktf's Avatar
Today I got the front steam port stainless tubes made and installed..... I made and installed the feed heater hose from the steam port block to the firewall..... Then I installed the fuel injectors/rails on the intake with new ARP hardware and got it mocked up on the motor again(I can't bolt the intake down yet because I am going to need to get under it when I wire everything)..... Last thing I got done today is figure out what fittings I will need to finish the fuel plumbing up front.....
Old Aug 1, 2016 | 11:49 AM
  #453
static low 92's Avatar
Looks fantastic.
Keep on rolling.
Old Aug 1, 2016 | 04:57 PM
  #454
franktf's Avatar
Originally Posted by static low 92
Looks fantastic.
Keep on rolling.
Thanks, I'm tryin.....
Old Aug 2, 2016 | 11:26 AM
  #455
Jimbo1367's Avatar
Well thought out enginebay.
Old Aug 4, 2016 | 09:29 AM
  #456
408GT's Avatar
Very nice build. I like the attention to detail thanks for sharing!
Old Aug 4, 2016 | 03:44 PM
  #457
franktf's Avatar
Well thought out engine bay.
Thanks.....
Old Aug 5, 2016 | 01:01 PM
  #458
Cheese Weasel's Avatar
Man, I love how you did that! Would you mind sharing what fittings you used to connect the steam ports to the stainless line??
Old Aug 5, 2016 | 06:09 PM
  #459
franktf's Avatar
The fittings in the heads are ICT Billet I got off eBay..... Here's a link: http://www.ebay.com/itm/LS1-1-8-COOL...sAAOSwoydWlDVv
Old Aug 6, 2016 | 09:58 AM
  #460
Excellent, thank you. I was able to find their website & also their Amazon store since I don't utilize eBay. Looking at their website shows that they offer a fair bit of stuff that could be useful for these swaps.
