10 Second Club Now you are haulin! 10s are sweet
10's or bust
Old 07-10-2016, 10:17 AM
wichoms4's Avatar
Default 10's or bust
How is it going folks. It's been a wail but I'm back. Would like to post my project 1998 Camaro SS. Quick run down, MS3 cam with 02 top end includes ls6 intake, th400 trans, Nitrous outlet plate kit and basic suspension mods. Hoping to break into the 10's with a 100shot and circle D nitrous converter. Gears are 3.90 on a Mickey Thompson 295/55/15. Any advise besides the mods I posted to help me get into the 10's I would greatly appreciate it.
Nitrous kit not installed yet
Th400 trans. No T-brake
1998 Camaro SS
Viking Performance struts and shocks, 300lb Spring rate
Old 07-10-2016, 01:48 PM
HCI2000SS's Avatar
I see no reason that you couldn't get into the 10's with your current setup
Old 07-10-2016, 03:08 PM
wichoms4's Avatar
Thanks. Car is still close to full weight. I won't know til I weigh it. It's a bit tuff to get into those low et cause my local track has bad track prep. (Sac raceway)
Old 07-15-2016, 02:53 AM
dannyz's Avatar
Keep us posted!
Old 07-16-2016, 01:52 AM
wichoms4's Avatar
Originally Posted by dannyz
Keep us posted!
Sure will. I will be posting my converter as soon as it comes in and a few other pictures. Motor is coming back out to finish up a few minor engine bay touch ups as well as the converter & nitrous install.
Old 07-16-2016, 07:54 PM
wichoms4's Avatar
Few more parts going in as soon as my converter comes in.
Stock 4l60E flex plate.
OEM A4 shifter
UMI th400 trans cross member
Th400 trans cooler
Old 07-18-2016, 08:01 PM
hfthe3rd's Avatar
I'm trying for 10s with no nitrous I think you will be mid 10s with nitrous
Old 07-19-2016, 10:09 AM
ragtopz28's Avatar
^^I would agree with this^^ (SEE MY SIG)
Old 07-19-2016, 02:00 PM
wichoms4's Avatar
We will see how it turns out. BTW car was a M6. Motor is coming back out to install th400 and fix my brake lines. Now it's just a waiting game lol
Old 07-26-2016, 06:35 PM
wichoms4's Avatar
Circle D converter finally came in.
Old 07-26-2016, 06:37 PM
wichoms4's Avatar
Thanks Chris awesome customer service.
Old 07-26-2016, 07:55 PM
wichoms4's Avatar
Motor is out. Going to clean up a few things. Also going to be installing new struts and shocks with new strut mounts. Would like a k member but a little tight on money. Il keep you guys posted.
Old 08-18-2016, 12:05 AM
wichoms4's Avatar
Quick update. Motor and trans went back in. Still need adjust suspension and few more lbs removed.
Old 08-22-2016, 10:18 AM
wichoms4's Avatar
Quaick update. Finally got around to washing the car. Still waiting on my driveshaft and off to get tune. Unsure what shot to start off with. Going talk to the tuner and what he suggests
Old 08-27-2016, 10:57 PM
wichoms4's Avatar
Quick update. Went to my local drive line shop and got my drive line made. Big thanks to Steve over at Southbay Driveline. Got sponsored I was surprised. He spec me a 3.5 drive shaft rated 1000tq. Still need few more parts and off to get tune.
Old 12-03-2016, 07:22 PM
64post's Avatar
Take it out to Sonoma or Sac yet?
Old 12-08-2016, 05:39 PM
tnmotown's Avatar
I don't see a problem with you going at least mid 10's. My cam is similar to yours and just on motor I made a 11.1 pass at Sac raceway this past wednesday. Prep is key though, I was slip and sliding when I tried to use the nitrous.
Do you have 15x8 or 15x10 rear rim? I like that tire size. Keep us posted!!
Old 12-28-2016, 08:45 AM
wichoms4's Avatar
hows it going. Sorry for late reply iv been busy with the family. Car is about done. Winter here so won't be out till February. Il be sac test and tuning. Il post a few more pictures of the recent mods done since then.
Old 12-28-2016, 09:29 AM
wichoms4's Avatar
Nice man. im running 15x10 rears. think i saw your car on a post MAXLIMIT posted on instagram.Your car is moving, just needs a anitroll bar aka drag sway bar.
Old 01-02-2017, 12:39 AM
wichoms4's Avatar
Finally came across this used Moser 9inch rearend. Should fix my worries about breaking at the track. Pretty excited it's been four years in the making. Stay tune for more.
Moser 9inch
Nodular iron casing 4.11 31 spline axles
Quick Reply: 10's or bust
