Drag Racing Tech
Old 07-26-2016, 02:20 PM
  #101
Nali6.2's Avatar
herd nothing but problems with fbody pans once you start going fast.. im ditching mine and putting a moroso in
Old 08-21-2016, 08:51 PM
  #102
Doublenickle's Avatar
Spun a rod bearing in my 98. Some of the other rod bearing look like they had some oil starvation issues. Pulling front wheels a couple feet off the track at launch and noticed oil gauge fluctuated some, but thought it was not enough to worry about. Changed to a Moroso pan and installed a low pressure light on the dash. Oil pressure good to go now.
Old 08-30-2016, 07:58 AM
  #103
BlackSS4thgen's Avatar
Yes the Moroso pan was well worth the investment. Im 7-800 hard miles into the new motor. Oil pressure constant at 20-25 at idle and 75-80 at wot. With a high volume ls6 pump.
Old 08-30-2016, 08:00 AM
  #104
Originally Posted by Joe Verolini
What did your final weight end up at?
I havent cut anything in the rear of the car besides the bump stops and removed the plastic bumper. 3,380 with me
Old 08-30-2016, 08:02 AM
  #105
Originally Posted by Heavy H.P.
Ditto I want to know that also. What was it with out you being in the car?
Also why not A2W?
3,380 with me. I went air to air because I primarily drive the car on the streets. It rarely see's track duty. So I didnt want to deal with constant upkeep. I might switch for next season and race the car more. Since I put the bullseye on it is too much power for that tire on the street. It spins all of third gear. When It was 877whp it would rarely spin 2nd. Im guessing its up over 1,000 now.
Old 09-16-2016, 01:34 PM
  #106
Ordered a Rossler Terminator 3 trans. Hopefully it comes in a timely manor so I can get some good slips to post up.
Since I will have a functional trans brake and all
Old 10-02-2016, 12:32 PM
  #107
Old 10-02-2016, 12:35 PM
  #108
I never wanted to put a chute on the car but unfortunately it does not stop the greatest. So since it went 153 so easy on 18 psi with the 75mm ... after driving on 22-23 psi with the bullseye 800 tct and a good working trans it makes me nervous. So it is definitely going to do good.
Old 10-02-2016, 06:22 PM
  #109
98 grmrpr's Avatar
Sharp looking trans!
Good luck.
Old 10-06-2016, 09:30 PM
  #110
I never intended to have this much into this car or even make it this RaceCar. But it is what it is. Hopefully it is fast or Ill be sad lol
Old 10-07-2016, 11:06 PM
  #111
hfthe3rd's Avatar
I would love to cut my front end up like you did to save some weight . I wonder if I could do something like you did and still mount the front radiator and fans
Old 10-09-2016, 01:31 PM
  #112
Not how I wanted to run my first 8 second pass but I guess I shouldnt complain. Im just sad my first 8 second pass was a half *** one lol.
I only left on the brake and 5 psi because I wanted to go in a few testing stages before I ended up on the bumper or something crazy. So I left soft .... If I would have had just one or two more passes in her it would have been much better.
Old 10-09-2016, 01:33 PM
  #113
I have had cooling system pressure for a while now so I was assuming it was lifting the heads but nothing crazy yet. Well She blew right around the 1/8th but I peddled it to the end atleast for the slip.
Old 10-09-2016, 01:42 PM
  #114
I have been waiting for the gaskets to blow for some time now. I found these gaskets on ljms website so I thought they would be fitting. People always say to use the ls9 and it clearly works but I want to see if these being for the smaller bore work better.
Old 10-09-2016, 02:01 PM
  #115
80/TA/LT1's Avatar
Default Front end
First off I really love this car man, beautiful. I was wondering if you have more detailed pics of your front end, I've been wanting to do a once piece removable on mine, I just can't visualize the framing and attachment points, especially for the headlights and how the fenders mount.Mines an lt1 nose but shouldn't be too different. Any help would be awesome, thx a lot and congrats on that 8 sec pass!
Old 10-09-2016, 02:37 PM
  #116
I think the only pictures I have are on here. I just kind of took it a little at a time. It was time consuming for sure.
Just makes it easy to work on.
Old 10-10-2016, 09:58 AM
  #117
transbird95's Avatar
This has been one of my favorite threads of all time on here! Great job on the 8's!
Old 10-10-2016, 10:05 AM
  #118
LS1Tech Premium Sponsor
Aaron at SDPC's Avatar
Nice build!
Aaron @ Scoggin Dickey Parts Center
Email:Aaron387@sdparts.com
Phone: 1-800-456-0211 Ext: 324
Old 10-10-2016, 12:06 PM
  #119
Campbell13's Avatar
Great work here! Super nice car! helps keep me pushing through the slow time on my FI build.
Old 10-12-2016, 06:35 PM
  #120
Thanks guys! But I am not finished yet. Still a few more track days and nice cool weather before winter in Michigan arrives.
