1970 caddy sedan deville(sinister) lq4 s475 turbo cam=)
Old 10-07-2016, 06:12 AM
  #141
Tomhames's Avatar
Hoorrraaayyy!!!!
You know we need vids!
Old 10-07-2016, 04:38 PM
  #142
rpm-inc's Avatar
Awesome!! My caddy getting close as well!
Old 10-07-2016, 10:56 PM
  #143
slocaddy's Avatar
Originally Posted by Tomhames
Hoorrraaayyy!!!!
Lol! I know, but I'm just getting good at posting pics!
Was such a sigh of relief to know that all the harness /wiring of the car and heads off/cam change , that I actually did it right
Old 10-07-2016, 10:58 PM
  #144
slocaddy's Avatar
Have you updated your thread? I need to check it out
Old 10-07-2016, 11:04 PM
  #145
slocaddy's Avatar
Hot side pipe that connects to manifold before....
Hotside pipe that connects to manifold after
Old 10-07-2016, 11:10 PM
  #146
slocaddy's Avatar
The periscope, aka sewer pipe.....
Do you like my green teather???
Old 10-08-2016, 05:01 AM
  #147
rwb
rwb's Avatar
Smile
Does it work?? Then it's awesome.
Old 10-08-2016, 09:10 AM
  #148
slocaddy's Avatar
Yea it woks, just needs tweekin' lol
This is the basic plan. If I could ditch the hood hinge, I'd be golden
Old 10-10-2016, 10:36 PM
  #149
slocaddy's Avatar
Well, spent today screwing up more stuff than things I made right, the braket to hold the s475 is kicking my ***! I'm making something that bolts to the back of the head to help out the hot side with supporting this big bitch.
If I ever do another turbo build , it will be twins. Physically smaller twins.
I'm not sure I ever really envisioned making the braket , buy it wouldn't have been this pos I'm making. ....it will be strong, it will do the job, but she gonna be ugly.
I shouldn't even be showing this ,but here is the start......
It's being "built"..... from 1/4" plate, and will be made to bolt together so the braket itself can be removed without having to take the up pipes off with it as one peice
Old 10-10-2016, 10:41 PM
  #150
slocaddy's Avatar
Been waiting so long to finally see this happen!
Caddy's vitals
Old 10-11-2016, 04:50 PM
  #151
rwb
rwb's Avatar
As for your ugly bracket, beauty is in the eye of the beholder. If it works it is a beauty.
Old 10-11-2016, 05:33 PM
  #152
slocaddy's Avatar
Well, here it is.... 1/4" plate steel and you can still make it wiggle, one the rest of the hot side is on there will be no more wiggles lol
Just didn't want this hanging off manifolds alone, should be plenty strong
Old 10-11-2016, 05:39 PM
  #153
slocaddy's Avatar
Check this out.....
22's with 235/30/22
Old 10-11-2016, 05:44 PM
  #154
rpm-inc's Avatar
I thought you were making something ugly? It looks good!!!
Old 10-12-2016, 11:50 PM
  #155
slocaddy's Avatar
Thanks, with some (alot) of grinding and some spray bomb it looks ok lol
Old 10-13-2016, 12:00 AM
  #156
slocaddy's Avatar
So I'm at a stand still on the up pipes till I get more bends in, I called all over my area and no luck. ......so I switched to the down pipe /rest of exhaust and it's almost done
Downpipe supplies. ....
Clearance from firewall and transmission
Getting ready to to make semi-oval pipe......
Old 10-13-2016, 12:04 AM
  #157
slocaddy's Avatar
This was as far as I got before I ran out of bends I wanted to use, this is its best angle, turned out like crap, going to redo.
Old 10-13-2016, 05:05 AM
  #158
Tomhames's Avatar
It all looks great man.
I think you can just Put the video on utube then share the link-?
Wheels look really good of course!
Just an idea on maintaining a consistent height on your custom oval piping - use a length of ripped 2 by 4 ( cut to your desired height) then crush to that inner spacer (?) .... if there is a concern for distinct edges from the inserted wood just hit it ( the wood) with a router ( 1/4 round over bit).
Old 10-13-2016, 11:06 AM
  #159
Bad Apache's Avatar
I've been watching your build and every time I do I giggle. This thing is going to be very cool! And if that's an ugly bracket, I've been building those for years. You dressed it up nice. I like the new wheels and tires, but I'd have to sport some 15 inch steelies and blackwalls and go hurt some feelings with that bitch.
Old 10-13-2016, 11:20 PM
  #160
slocaddy's Avatar
Thanks! I'd like to see some wide whites on it also.....prob get another set eventually
Quick Reply: 1970 caddy sedan deville(sinister) lq4 s475 turbo cam=)
