~~~2002 Trans Am F1C PROCHARGED 376 BUILD THREAD~~~
Old 10-13-2016, 01:08 PM
  #121
Rise of the Phoenix's Avatar
You may have already stated this, but is the FAST 102mm intake ported?
Old 10-13-2016, 03:13 PM
  #122
conan's Avatar
Looking good...
Old 10-14-2016, 09:08 PM
  #123
SStressin's Avatar
Originally Posted by josh4ku
Stand up radiator and condenser is completed. Now off to the body shop today to have the engine bay painted
Looks great! Did you have to modify the lower radiator support? I am standing up my griffin aswell and trying to see how people do them. Any info on yours would be great.
Old 10-15-2016, 08:28 AM
  #124
josh4ku's Avatar
Yes custom a/c lines. Fast 102 intake is not ported. Yes the the. Yes the. Bottom support was modified. The top of it was cut out , welded in some brackets to hold rubber pieces for the radiator to sit on. I'm really happy with the way it turned out. Once it all gets painted I think it's going to look really good.
Old 10-28-2016, 07:30 AM
  #125
josh4ku's Avatar
Default Update
well I quit my job a few weeks ago so that has really slowed things down mentally for me. I have all the parts it just needs put together!
Pushrod length measured. Ended up with 7.380 no last measurement. Went with a 7.425 length pushrod. Now waiting for valve covers etc to get back from the powder coat shop.
Also the stand up radiator fab is completed and entire engine bay is painted. Went ahead and has them do the ceta mod while it was in the body shop.
Old 11-06-2016, 07:29 PM
  #126
josh4ku's Avatar
Old 11-07-2016, 12:38 PM
  #127
nandos_z28's Avatar
Was the Fast 102 hydro dipped?? Nice work so far! Looks good!
Old 11-14-2016, 07:31 PM
  #128
josh4ku's Avatar
Yes I had it dipped
Old 11-17-2016, 06:10 AM
  #129
josh4ku's Avatar
Old 11-17-2016, 10:09 AM
  #130
UNDER PRESSURE MOD
The Alchemist's Avatar
Very nice... I like how clean it looks from a style perspective.
Old 11-19-2016, 11:49 AM
  #131
josh4ku's Avatar
Old 11-26-2016, 07:23 AM
  #132
josh4ku's Avatar
Slowly seeing progress.
2" Kooks headers showed up finally after 2 'months. I sure hope I don't regret these big headers.was going with stock rubber motor mounts,just ordered some poly mounts to help with clearance. I'm guessing clearance will be tight with these. Rubber mounts will probably deflect too much.
Nick Williams throttle body barely hits the o ring on the fast intake at the bottom. Sold t and ordered a Holley 105mm. Fitment always seems to be a problem!
Just eye candy
Old 11-27-2016, 04:00 AM
  #133
8 Second Truck Club
Blown06's Avatar
You absolutely will not regret the 2" header decision. Header design and scavenging bull **** goes out the window when your forcing pressure into the intake manifold. On a procharged setup, as far as headers are concerned you really can't go too big.
Old 11-27-2016, 12:37 PM
  #134
josh4ku's Avatar
Im more worried about the fitment, I am running a BMR K member so hopefully that will help. I was hoping to run new stock engine mounts to keep vibrations from the cab, but Im not sure if I can get away with that movement of the engine with those mounts.
Old 11-27-2016, 01:23 PM
  #135
UNDER PRESSURE MOD
I wish I had gone with 2" headers rather than the 1 7/8 I went with.
Old 11-27-2016, 09:49 PM
  #136
josh4ku's Avatar
Engine should be going in next week. So i will let you guys know how they fit
Old 11-28-2016, 09:05 AM
  #137
conan's Avatar
Go poly on the motor and trans mounts. If everything is balanced right you shouldn't have a ton of vibration in the cab. I will never go back to stock mounts again especially on my 6 speed car. There is no more transmission / shifter shake with the poly mounts.
Old 11-28-2016, 09:44 AM
  #138
Taubr Unit's Avatar
I had 2" Kooks on my car and they fit perfect! Didn't have to clearance anything and dropped right in so you should be good.
Old 11-29-2016, 06:51 PM
  #139
josh4ku's Avatar
Awesome!
Old 11-29-2016, 06:53 PM
  #140
josh4ku's Avatar
Stay tuned for some progress next week. Engine will be completely assembled friday. Then 4l80E will be hooked up. Next week hopefully the K member will get swapped out and new front end suspension.
Procharger pulley will be a 4.25". This will put the F1C impeller speed at 58,000.
Quick Reply: ~~~2002 Trans Am F1C PROCHARGED 376 BUILD THREAD~~~
