1970 caddy sedan deville(sinister) lq4 s475 turbo cam=)
Old 11-05-2016 | 01:11 PM
  #241
slocaddy's Avatar
Originally Posted by Bad Apache
I've said it before and I'll say it again. This car is just plain cool! Having good brakes and steering is critical in a 4000lb+ vehicle. Great work seeing it through!
Thanks alot! It's been a learning experience with the hydroboost stuff, it was getting tempting just to throw the vaccum booster back on it, but in the grand scheme of things I'm glad I made it work
Old 11-05-2016 | 10:25 PM
  #242
slocaddy's Avatar
I've wanted one of these ever since they came out!
Old 11-06-2016 | 11:33 PM
  #243
slocaddy's Avatar
Well, got it wired, looks cool, thats pretty much it though......so looks like i will need to do the resistor mod
Old 11-07-2016 | 08:06 PM
  #244
slocaddy's Avatar
Well, let me bring something to the table!
This is a simple, solderless way to boost your tach signal
Parts
Slip heat shrink over resistor
Couldnt get any clearer, slip ends of heat shrink inside splice crimp
Signal wire jumped over to 12v power to the tach
Old 11-08-2016 | 12:14 PM
  #245
slocaddy's Avatar
So did some more work to the shifter, added a momentary botton for the tow haul
Wires were already under the carpet
Button installed
Old 11-10-2016 | 12:04 PM
  #246
Suncc49's Avatar
This is an awesome build man!!
Old 11-10-2016 | 12:19 PM
  #247
denmah's Avatar
you posted this on sloppy right!? i love this thing
Old 11-10-2016 | 02:23 PM
  #248
slocaddy's Avatar
Thanks A lot man
Old 11-10-2016 | 02:30 PM
  #249
slocaddy's Avatar
Yea, a friend of mine posted it, he has the red twin turbo colorado, sweet little truck, I'm not on any social media exept tech lol!
I don't know a thing about tuning, and he was kind enough to help me get it going on a base tune, but it has some idle issues and trans shifting stuff to be worked out, I'm hoping to take it to daytona for the turkey run, so we'll see
Its so fun to hear the turbo noises that shouldn't come from this car lol
Old 11-11-2016 | 04:11 PM
  #250
slocaddy's Avatar
Got the third nozzle, maybe more for looks at this point, but should help us find the limit one day lol
Old 11-14-2016 | 07:49 AM
  #251
jimmyg's Avatar
I'm interested in the meth kit . Does it have its own map sensor ? Or does it just need a boost / vacuum line from manifold? I'm thinking of getting the same one and replacing my boost gauge with the vc50 controller .
Old 11-14-2016 | 11:51 AM
  #252
slocaddy's Avatar
This one uses a tiny vacuum line to the manifold, just seemed like the easyiest way to go
Old 11-14-2016 | 03:57 PM
  #253
jimmyg's Avatar
Ya I think I'm gonna get the same one
Old 11-14-2016 | 07:05 PM
  #254
slocaddy's Avatar
It's very simple to install, and the gauge is very easy to set up/make changes.
Im very anxious to get it into use=)
Old 11-18-2016 | 12:45 AM
  #255
slocaddy's Avatar
Crude, yes.
Works, flawless
Finally got the gas pedal hooked up instead of having to hold it and operate the cable by hand...........
Old 11-21-2016 | 08:54 PM
  #256
slocaddy's Avatar
Crunch time, been wrapping up odds and ends, someone is working on a base tune for me .
So ill be using this to monitor some things
New rear meats
Old 11-22-2016 | 08:51 AM
  #257
slocaddy's Avatar
Skirt fits too
Proper gauge install......
Old 11-22-2016 | 11:43 AM
  #258
BudRacing's Avatar
What's the width on those rear tires? That skirt is a bit of a concern for anything wider.
Old 11-22-2016 | 03:43 PM
  #259
slocaddy's Avatar
There 265/50's, bout 9.5"wide, bout as wide as you can fit under her skirt lol
Old 11-23-2016 | 10:48 AM
  #260
BudRacing's Avatar
Haha, wow. That angle shows quite the bulge.
Quick Reply: 1970 caddy sedan deville(sinister) lq4 s475 turbo cam=)
