2000 NBM M6 SS Turbo build
Old 11-26-2016, 07:39 PM
SteenH's Avatar
Sorry- not much to show of the exhaust really but here's the motor mounts I made- there was a TON of room for the 4"
And then I have a hooker max flow muffler under the cat hump in the floor, nice idle, nice sound level driving around
Edit: how far do you expect the walbro 450 to take you? My 400 died on me, just trying to decide what to do for next year
Attached Thumbnails 2000 NBM M6 SS Turbo build-photo179.jpg   2000 NBM M6 SS Turbo build-photo160.jpg
Old 11-28-2016, 03:34 PM
KyleLanter's Avatar
Attachment 558540
Attachment 558541
Everything looks good on your set up. I am really looking to wrap my DP back around and exit the driver side of the motor so I can retain AC.
I am not really sure to be honest with you on the pump. I have read mixed things on this and other forums ranging from 600hp to 1200hp with pump gas. I am shooting for 700-800 to the tire. If one pump will get me there I would be pretty happy. If I have to go two pumps I would be tempted to turn the boost up more. . .
Old 11-28-2016, 09:30 PM
KyleLanter's Avatar
Spent the night resealing my 9" it has a slight leak few drops here and here.
Quick question though I plan to go SD for my tuning and a gm 2 bar map sensor. I have done a lot of searching and reading on ls1tech but get some many mixed opinions. I don't think I'll run more than 15lbs especially with a single walbro pump so a 2bar should work for me. As far as SD goes what all should I have to be ready for the tuner? He uses HP tuners.
Old 12-08-2016, 07:38 PM
KyleLanter's Avatar
Little bit done tonight I got the fuse box trimmed and tucked back to make more room for the charge pipe
Also trimmed my slp grill the way I wanted for the intercooler. Happy with the result minus a little filler and paint needed to finish
Old 12-09-2016, 10:15 PM
camaro hotwheels's Avatar
Very nice !!!
I also am looking to see how this kit fit.....
I have this kit also....
Subscribing to your thread.
Old 12-15-2016, 01:49 PM
KyleLanter's Avatar
Originally Posted by camaro hotwheels
Very nice !!!
Thanks and the kit fits great I have had no issues to speak of. Drivers header put up a small fight but nothing too bad.
Old 12-28-2016, 09:36 AM
KyleLanter's Avatar
Ordered the last bits for my fuel system so I will be working on that when they arrive.
- Earl's ultra pro PTFE line -8
- Earl's straight and 90 degree fittings -8
- Earl's 10 micron in line fuel filter -8
- Earl's efi quick disconnect fitting for the fuel hat -8
- Earl's -8an Y Block
I also ordered my Gm 2 bar map sensor for my Speed Density tune that I will have this spring. Still debating on the tuner I will be using I have looked into a few and want to stick around Indiana so it is not a long drive. Any recommendations would be appriciated!
Old 01-08-2017, 10:08 PM
KyleLanter's Avatar
Got a bit done this weekend. Walbro 450 pump installed and racetronix Hotwire kit added. Also got some of my earls fuel lines and fittings assembled and on the tank.
Old 01-30-2017, 03:38 PM
KyleLanter's Avatar
Got some more items checked off the list. Oil pan is drilled and tapped for the turbo drain line. Rear end is installed. Fuel lines have been ran and everything completed with the exception of a mounting bracket for the fuel pressure regulator.
I am thinking I will have to move the alternator in order to run a 4" downpipe so I am planning that out. Also I am going to remove my rack and pinion since it is leaking. Hopefully I can just rebuild it and save some cash.
Old 01-30-2017, 07:54 PM
KyleLanter's Avatar
Old 02-02-2017, 10:47 PM
KyleLanter's Avatar
Got the moser and rear suspension in tonight.
Moser 9" 35 spline spool, founders da lca and phb, umi tunnel mount tq arm and sway bar, strange sa shocks
Old 02-05-2017, 06:56 PM
KyleLanter's Avatar
Old 02-10-2017, 02:20 PM
White.Lightning's Avatar
Nice build. In for updates!
Old 02-11-2017, 10:27 PM
KyleLanter's Avatar
Thanks white lightning.
Tonight i wrapped up my return style fuel system with the exception of one fitting that I ordered
Also installed and adjusted the qa1s
Old 02-13-2017, 09:36 AM
Gunters96lt1's Avatar
Awesome build!
Old 02-19-2017, 06:24 PM
KyleLanter's Avatar
Relocated my power steering lines to make some more room for a down pipe. Also got a new ps pump since mine was leaking.
Old 02-21-2017, 07:17 PM
KyleLanter's Avatar
Wrapped up be steering tonight with a power steering cooler. We will see how it does at $18.00 it's worth a try.
Excuse the surface rust I have some rust treatment and paint for that.
Old 02-24-2017, 09:09 AM
KyleLanter's Avatar
Got some more accomplished last night. Received my final parts which includes two pusher fans, 80lb injectors, and a different oil drain fitting to add some more angle to my drain line. Got the oil drain and supply lines finished as well as the injectors swapped and all fuel lines righted. Next on the agenda is fans and a fair amount of wiring then I will be ready for an exhaust and tune.
Old 02-24-2017, 09:23 PM
  #39
KyleLanter's Avatar
Getting the fans wired up tonight
Old 02-24-2017, 11:15 PM
  #40
KyleLanter's Avatar
Took a break from wiring to clean up my rough cuts on my bumper and grill.
Quick Reply: 2000 NBM M6 SS Turbo build
