Boosted 5.3s What rwhp are yall making with what setup?
Old Feb 2, 2017 | 12:23 PM
ls1charged's Avatar
i wish people would post cam specs or ballpark the specs if you dont want to give out specifics instead of "custom cam", doesnt tell us anything
Old Feb 2, 2017 | 02:42 PM
yenkomike's Avatar
https://cimg5.ibsrv.net/gimg/ls1tech...1231285237.jpg
here is a pic of one I did. hot side I made with 2.5 tubing.
2005 5.3 all stock internals with the stock rings opened up to .022. isky triple 12 cam from stock48, stock 706 heads and truck intake. on3 78/75 cast cheap turbo. running deka 80# injectors at 58 psi base pressure. pump e85 right at 100%dc @ 20.3 psi boost it run 9.44 @141 mph at 3550 lbs. thru a th400 with 3200 converter and 3.73 gear. 31" slick.
click link for pic. I have a video but cant get it to load.
Old Feb 3, 2017 | 11:41 AM
Project GatTagO's Avatar
There are ghosts in this thread...RIP...
Andrew
Old Feb 4, 2017 | 03:48 AM
Blown06's Avatar
8 Second Truck Club
I'd kill to see those guys with the 4 second (1/8th mile) mustang with the old stock 5.3 post up a chassis dyno. I don't think they dyno'd it, but given the way it ran on 42 lbs. of boost, it would likely turn this site on its head. That thing had to be in the 1500 hp range at least at the crank.
Old Feb 4, 2017 | 12:01 PM
JoeNova's Avatar
Restricted User
Barry cook make like 1150hp/1250tq on a chassis dyno with a stock L33. Spit a rod eventually but he had been running it hard for a few years.
Old Feb 5, 2017 | 02:03 AM
Blown06's Avatar
8 Second Truck Club
The mustang I'm talking about was met with destruction as well, but not after beating on it for a couple seasons. It ended up lifting the head (imagine that, lol) and torched the block and head. Upon tear down there were some bent rods as well. The crazy part is that who knows how long the rods where bent. Crazy enough, the bent rods probably lowered the compression a little bit and helped keep it alive.
The things that some of these people get away with on these cheap motors is enough to make me slit my wrists sometimes. I constantly battle an internal demon that laughs at me for throwing a ton of money at my iron 4 head bolt 408 that still doesn't make the power they are.
Old Feb 5, 2017 | 09:43 AM
Forcefed86's Avatar
I hear ya! Had more trouble with machining BS trying to use aftermarket parts than I care to admit. Wish I would have stuck to factory short blocks as well. Tired of pulling apart "built" motors when guys are making twice the power on factory original stuff and racing the whole season.
Old Feb 6, 2017 | 01:51 PM
Narxoleptic's Avatar
I do want to commend Cody Preston for searching before starting a new thread!
Old Feb 8, 2017 | 08:38 AM
ken6881's Avatar
No dyno but at 3030lb we went 6.33 to the 1/8 on 11lb of boost 11* of timing. 11.0 afr
Ljms stage 2 cam.
Gt45 69mm
No intercooler
Renegade 110 fuel
Intake air temp 215*
2004 5.3
