FRONT WHEEL, REAR WHEEL, AND ALL WHEEL DRIVE DYNO TUNING
DYNO TUNING SPECIALS AND RATES
Professional dyno tuning is the ONLY way to maximize your vehicle's horsepower and torque; And nobody dyno tunes better than Granatelli! Granatelli offers YOU the most advanced chassis dyno tuning center in the Southern California area. Granatelli features an 1800HP AWD Mustang inertia chassis dyno with full diagnostics, wideband O2 sensors, air / fuel ratio monitors and much more. We'll fine tune your air / fuel ratio for maximum power on pump gas with NO ENGINE KNOCK. Need installation? Granatelli is THE expert at installing turbos, superchargers, suspension, brakes, exhaust, and much more! We offer professional installations at our facility by ASE certified and Granatelli trained mechanics. Don't take chances with your hard earned dollars and valuable time...get your car or truck Tuned By Granatelli now!
Chassis Dyno Tuning
- Improves power & driveability on PUMP GAS!
- 1,800hp AWD Mustang inertia chassis dyno
- Wide Band O2 Sensor Tuning
- Air / Fuel Ratio Monitoring
- Exhaust Gas Temperature Monitoring
- Real Time Data Acquisition
- Variable Load Simulation
- OBD-II Diagnostics
- Custom ECM Programming
We don't just tune on the car dyno we also have a full Engine dyno too
What's all involved with getting the engine dyno'd?
Would I bring the engine (without transmission?) on a stand with the PCM and harness attached?
Do I bring a fuel cell/pump/regulator?
Would I be able to have you tune using my personal HP Tuner account, or at least be left with an unlocked tune, that can be dyno tuned after it is installed?
