Shift Lights
Old 02-28-2017, 02:39 PM
Bama99z's Avatar
Default Shift Lights
Looking for recommendations on shift lights. Does anyone know if Harlan still makes them? I've tried to contact whom I think is the manufacture of them turbohawk80 via e-mail with no luck. What's everyone running Pro's Cons?
Old 02-28-2017, 04:44 PM
455GTO's Avatar
When I had the T56 in the car I installed the raptor shift light in the HVAC vent and fit perfect... Super easy to adjust and worked great. Still have it in the car as there was no need to remove when i went to the 4L80e.
Old 02-28-2017, 09:04 PM
Bama99z's Avatar
455GTO, that is where I wanted to mount mine as well. Where you adjust your RPM's it that part under the gauge pod or somewhere else?
Old 03-01-2017, 10:39 AM
455GTO's Avatar
The adjustments are on the side of the light. You can adjust RPM by 100 until you get your desired setting.
Old 03-01-2017, 01:57 PM
Firebirdmuscle's Avatar
Same situation here.
Had the raptor while I was a 6 speed and it worked great. I'm still using now after the 80e swap. It's in the same location and is very easy to get to to change rpm of if you need to after you originally set it.
Quick Reply: Shift Lights
