2000 z28 4.8l turbo build
Old 03-17-2017, 07:43 PM
ep142's Avatar
Both pumps installed
The 2 studs are for the second pump. Both will have separate relays and dedicated wires to the altenator
80lb deka injectors
Old 03-18-2017, 09:20 AM
ep142's Avatar
Started installation, fit great from the mock up car
Old 03-25-2017, 04:47 PM
nocooler's Avatar
Looks amazing - any shots of the turbo inlet pipe? It's got to be tight.
Old 03-25-2017, 11:08 PM
ep142's Avatar
I do I will get the rest of them up
Old 03-26-2017, 01:19 PM
ep142's Avatar
Was going to buy a power steering relocation mount but decided to make it instead
Fits nice next step bolt the pump on
Works great, next step is to move the altenator
Old 03-28-2017, 07:42 PM
ep142's Avatar
Made a lower altenator bracket to kick the altenator out, the ear on the top left is to mount the trans cooler line to
Better pick in the correct orientation. The tube at the left bolts to the stock altenator bracket then the altenator swings out and bolts to the bracket in the right
Old 04-11-2017, 07:43 PM
ep142's Avatar
Getting the air filter pipe to the turbo was kind of tight but worked out nice. I welded a bracket to the filter pipe and installed captured nuts so I could bolt threw the altenator bracket into the filter pipe
Getting closer
Old 04-11-2017, 07:52 PM
ep142's Avatar
I got a good jump on the exhaust it exits out of the turbo 3.5 inch then I made an oval exhaust thats 2.5x5 inches then goes into the 4 inch that I had previously made
All welded and painted
Old 04-11-2017, 08:44 PM
MY_2K_Z's Avatar
Looking good man. Love how different this build is.
Old 04-11-2017, 09:24 PM
ep142's Avatar
thanks just wanted to do something a little different but mainly to keep the a/c and stock fans and radiator
Old 04-13-2017, 10:01 PM
ep142's Avatar
Charge pipes welded and ready for wrinkle coating
Old 04-13-2017, 11:33 PM
brandon6.0's Avatar
nice!
Old 04-14-2017, 09:51 AM
nocooler's Avatar
Looks good man - I like how you made your own oval exhaust piping.
Old 04-14-2017, 12:19 PM
merim123's Avatar
car looks great! but...what happened to the basketball hoop?
Old 04-14-2017, 10:37 PM
ep142's Avatar
much better then spending alot of money on something you can build your self
Old 04-14-2017, 10:38 PM
ep142's Avatar
it's lowered way down so my 4 year old can make it lol
Old 04-14-2017, 10:46 PM
ep142's Avatar
All back together and ready for some tuning
I didn't get a pick of the charge pipes wrinkle coated
Old 04-21-2017, 08:59 AM
ep142's Avatar
Found this a/c gauge pod that still allows the air to blow past. Installed innovative boost and wideband gauge
Old 04-21-2017, 11:02 AM
  #39
merim123's Avatar
link for that gauge pod?
Old 04-24-2017, 07:40 PM
  #40
ep142's Avatar
can not find the link must not make them any more
Quick Reply: 2000 z28 4.8l turbo build
