Nitrous 5.3 build
#63
Was going to drop this in the original build thread, but I guess I will leave it here instead. The motor passes aren't my fastest, but the base timing is the same as my first 2 nitrous passes. In the second nitrous pass the window switch was set to low so the kit was turning off before my shift point.
#68
The big hex key is 17MM amd you can get it at "VatoZone" spent two days trying to find one....
#69
#70
Swapped out the converter and headed to the track last night. Didn't get any clean passes, but learned a lot about what the car likes and doesn't. 1st pass was a 1.332 60' and then it fell on its face after the 1-2 shift. Adjusted the tune for the 2nd pass and the track was getting a worse 60 ft fell off slightly but it ran it's best 330 to date. I saw the guy in the other lane heading toward the center and I drifted out of the groove and had to let out before the 1/8 mile. The 3rd pass I got a little greedy on the leave and shook the tires. I will get some video up as soon as I can.
#71
uraloser2me2 - I'm digging this build and the car looks setup really well, thanks for sharing. Also your build confirmed my feeling that I want to wrinkle coat everything, looks damn good.
Any pics with it all put together with the wrinkle coated covers?
#73
That's what I was thinking, I thought I was gonna see a 2.5 60, not a sub 1.5!!
#76
Hope to have videos of Friday night up tonight. After looking at the data I really think the 150 shot has a 9.6x. Hopefully next time out I will get a solid run in. Also I know my candles lit 1st run was caused by the engine not being up to temp.
#79
No, I have other plans that weekend.
Here is the in-car of my second pass last time out. The track was going away so it didn't leave as hard as the 1st pass. I really wish I hadn't looked at the Blazer because it was on a pass. Ran 6.3 @ 91 mph to the 1/8 and I let off the throttle at 416 feet when I got it out of the groove. If I can put a complete pass together next time out it should go 6.0x to the 1/8 and 9.6x in the 1/4 on the 150 shot.
