Drag Racing Tech
Old 04-29-2017, 08:36 AM
  #201
BlackSS4thgen's Avatar
When does it end lol
Old 04-30-2017, 10:26 PM
  #202
worked on the car for the first time in what feels like forever!
Old 04-30-2017, 10:49 PM
  #203
8UALIVE's Avatar
What pistons did you go with? Are those the 3.800 bore from Brian tooley or lil John?
Old 05-01-2017, 09:15 PM
  #204
The Cartel's Avatar
Looking good! That block is awesome
Old 05-07-2017, 09:21 PM
  #205
The Pistons are 4.125 bore wiseco built for boost pistons from ljms or tooley still.
Old 05-07-2017, 09:39 PM
  #206
I have always hated bolting together car parts when they look so shiny and beautiful. They will never be the same.
Such a beautiful thing.
Old 05-08-2017, 10:05 PM
  #207
So with 11 more pounds for the tq arm mount and bolts, the rear axle is sitting at 178 pounds. The rear brakes weigh in at 25lbs. Bringing the total to 203lbs. 40 spline gun drilled, star flanged, aluminum center, and fab center housing with brakes is a whopping 30 pounds less then the old iron center ford case with oem rear lt1 brakes. Dang, that was expensive for 30 pounds. But it is pretty and the axle should be quite a bit stronger.
Old 05-08-2017, 10:08 PM
  #208
These things really are beautiful.
Old 05-08-2017, 10:09 PM
  #209
MS3PRO EVO systems have arrived. It pays to be a parts dealer sometimes!
Old 05-09-2017, 02:13 PM
  #210
82cetuner's Avatar
looking good. how much does the ms3pro setup run? and is it usable with any gauge setup ?
Old 05-09-2017, 02:14 PM
  #211
Corner Worker's Avatar
Haha....I worked at Aerospace for almost 5 yrs. Those are the drag race only rotors, and they do NOT like street use, so be mindful. The rotors get hot and bowl. regardless, they are light, and work. I have them on all 4 corners on my Chevelle and been on the car for 15yrs (although I have the heavier veined street rotor). Those axles are badass, and you wont hurt em. I really like your car man, and Im glad to see your progress. I wish you still lived in FL lol.
Old 05-09-2017, 02:16 PM
  #212
Will not work with your factory F-body gauges. You have to use a racepak, or Ive seen guys have good luck with using a tablet as a gauge cluster. RedRocketz28 has a nice setup in his car.
Old 05-09-2017, 02:17 PM
  #213
82cetuner's Avatar
i drive just fine on strange drag brakes. no issues driving around or driving to track a hour away. barly feel different than stock. but of coarse we all know you cant drive them hard with alot of heat cycles. but other than that they do just fine, just need longer to cool off
Old 05-09-2017, 08:07 PM
  #214
i drive just fine on strange drag brakes. no issues driving around or driving to track a hour away. barely feel different than stock. but of coarse we all know you cant drive them hard with alot of heat cycles. but other than that they do just fine, just need longer to cool off
Strange is not Aerospace. Trust me, they will warp like a bowl and bind up the caliper. I wasnt an office worker for Aerospace, I was a machinist, parts assembler, and later the tech guy you called when you had brake problems. The rotors they use are NOT hardened. They are simply cut out of a sheet of metal, double disc ground, machined, and chucked in a box.
Im not bashing the product, just going from experience. I use aerospace brakes on my personal car, which weighs 3000lbs and hasnt seen road use in 10 yrs. I dont run the drag only rotors though.
My close friend bracket races a mid 7sec 1900lb dragster. He had the dual caliper setup on his car, and the rotors bowled so bad he couldnt get the rotors free from the hats. He went with Strange brakes a few years back and hasnt had a single issue since.
Good American company, with an awesome owner, and they will work with customers who experience problems. So OP, try em out and if you have any issues, dont hesitate to call them.
Old 05-10-2017, 10:51 PM
  #215
Well dang! I guess I better be easy on them. Hopefully they have a different rotor design if they dont work for me. They seem like a great product. I was going to go with strange but I figured Id give them a shot.
Old 05-11-2017, 12:04 AM
  #216
blk00ss's Avatar
Haven't read all of the thread but the last few pages. So not sure if you've changed the master cylinder out or not? I believe a strange master cylinder helps prevent warping of the rotors from the factory power brakes.
Old 05-11-2017, 06:50 AM
  #217
Yes, you can upgrade to the veined rotors. It requires different caliper brackets, new rotors, and spacers that go between the caliper halves. I would try them out. If you do very little street driving, your car is light enough, you may get away with it for a little while.
Old 05-11-2017, 10:31 PM
  #218
Yes I do have a strange master. Probably why the oem brakes worked so poorly. lol
Old 05-11-2017, 10:33 PM
  #219
For sure. Ill be easy on them. I should have the car to about 3,200 with me. thats the goal anyways. I wont do a ton of traffic driving. Some cruising and hwy pulls every once in a while. Ill practice my coasting to a stop lol
Old 05-11-2017, 10:38 PM
  #220
Picked up a 5 gallon rhodes ice box with rule 2000.
