2000 NBM M6 SS Turbo build
#61
No problem guys if you have any questions just let me know.
Update- Local exhaust shops just do not want to try a 4" full exhaust and I kind of understand their concerns so I will be doing a bumper exit. I need to research some on removing the overflow tank and what all I need to do there then will use hurons 2 piece 4" so hopefully will have this thing dyno ready very soon.
Also I have a new PS pump and using the CBR alternator relo kit so no more tensioners. I am getting a horrible squeal when the car is idoling. Could this be the belt being too tight or loose?
if it is loose then take a look at the belt see if it have any slack while it idle
#63
one of my straight -8 an fittings was leaking so I swapped that out for a new fitting and unfortunatly the new one leaked the same as the old. Calling Earl's today to get their opionion. This is the only spot where a fitting is leaking so its odd that two have leaked. Hope to have it fixed soon since my downpipe is coming in from Huron tomorrow.
#70
Well its official I got everything finished up last night. I am waiting on a turbo blanket, exhaust 4" trim ring, and an air filter but other than those odds and ends the car is finished. Will put a few miles on the car over the next few days to prepar for my dyno tune appointment on the 23rd. Anxious to get that finished and get this thing to the track.
#73
LS1Tech Sponsor
Very nice build thread! We appreciate the support and glad you like your kit!!
Be sure to let me know should you need anything else, thanks again!
Jon
Jon
![](https://ls1tech.com/forums/signaturepics/sigpic36191_1.gif)
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
#78
LS1Tech Sponsor
![Cheers!!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cheers.gif)
