Transferring internals to another block, stock ring gaps huge.
I'm transferring the gen 4 24x internals I have from and 05 iron 5.3 block into a spare l33 block I have sitting here for my turbo iroc. Plan is 15-20# on e85. I put the rings in the block and used the caliper to set depth so it was even.
Top ring has .040 gap and bottom has .035, untouched. Came out of a perfectly fine running 05 Chevy. Since I'm transferring from iron to aluminum I thought maybe there was a difference in the bore slightly to make up for expansion rate differences, so I rechecked it in the iron block and its identical. Anyone ever seen this before???
This motor was also sludgy. Spent a lot of time degreasing and cleaning.
She's up and running now. Just the slightest haze out of the catch can. See what she does.
Zero trouble building boost on the brake. Brought it up to 0 and then leaned into it.
https://youtu.be/ZR1n-PM3AEE
yeah my newest motor has reused rings in a dingleberry honed bore and they smoked like fresh rings until I had some decent miles of loaded cruising on them.
hey are you on pump + meth or corn?
i'm trying to figure out how much to spray and when. we have the same turbo and spool about the same speed.
Gotta love the simple plumbing when theres no innercooler ! That was my first plan. No cooler and just water/meth. I chickened out before I even took a test drive. E85 is too hard to get where I am, so 93 is the rule. I took the meth off and stuck a 29x12x4 innercooler up front. Still have the meth kit though. If I can make 12 lbs on my setup and keep IACs down on just the cooler, I will sell the meth kit. If not, I recon it will go back on.
As long as you have a really good breather setup I'm sure she'll run great. Should be able to take some huge boost without ring problems!!
Question though, why would you re-use the rings? Is this a super budget build?
Ya I wouldnt re-use rings when swapping blocks. I would have bought cheap OEM replacement Mahle rings off Amazon for $40, threw a dingle ball hone job on the cylinders and set the ring gaps where I wanted them. Unless you had a time crunch and an event to get the car to, I would have spent the extra day of work to do it.
He seems to be a Denmah disciple . With the reuse of parts Ive seen from him (Denmah) on his turbo budget builds successfully, I don't question anything about the factory parts being reused anymore, LOL. Runum !
