4l80 flexplate with 4.8
Old 05-21-2017, 11:21 AM
68roadrunner's Avatar
Default 4l80 flexplate with 4.8
Guys I bought a 4l80e from a 2001-2002 Silverado it came with the flexplate below.
Can I use this with a 4.8LS motor ? Or will i need another spacer ? I will be buying a new converter from circle d ....
thanks for for the help
Old 05-21-2017, 07:16 PM
clinebarger's Avatar
If your buying a Circle D converter, You can run a 4L60E "Dished" flexplate.
Old 05-22-2017, 10:02 AM
Jon2295's Avatar
Default similar question
This sounds like what I was going ask about , but found this while searching before I posted. I have a 4.8 with the 4l80e and bought a torque converter for it not knowing that the bolt patterns were different from the ls flex plate. The converter was built to be used on an ls motor with a 4l80e. Can I just swap in a ls flex plate and have everything line up?
Old 05-22-2017, 03:27 PM
do you have the part number for this 4L60E "Dished" flexplate?
Old 05-22-2017, 11:03 PM
Originally Posted by 68roadrunner
do you have the part number for this 4l60e "dished" flexplate?
12606620
12602448
12580709
12563136
Old 05-24-2017, 08:50 AM
will i have to use longer bolts?
Old 06-02-2017, 08:12 PM
Does this look like the right flexplate?
Quick Reply: 4l80 flexplate with 4.8
