Morel lifters and Driven FR50 Oil....
There has been some questions from the Engine Builders that they want to run a 50W oil. The “W” winter rate doesn’t really tell whether you can use a specific oil with hydraulic roller lifters as I have learned from both John Callies and Lake Speed Jr. What does matter is the centistoke number.
Driven has supplied this chart on flow ratings on the Driven FR50 and other popular 50W oils:
Ambient Temperature Oil Flow Rates
Oil Driven FR50 VR1 Brad Penn
SAE 5W-50 20W-50 20W-50
60F 328 cSt 786 cSt 627 cSt
75F 213 cSt 451 cSt 373 cSt
90F 144 cSt 275 cSt 235 cSt
High Temp Flow (for reference)
275F 9 cSt 9 cSt 9 cSt
300F 7 cSt 7 cSt 7 cSt
I have talked with John Callies at Morel about the Data above and he said the FR50 will work with the Morel lifters. For those that want to run a heavier oil you can run this with your Morel lifters.
From: Ottawa Ontario, Canada - where arguing "DA" is for the slow and weak...
I have had good success with Castrol's Edge 5w-50.
As rated by the OEM: http://catalog.parentpetroleum.com/i...ol-edge/55248?
The actual 100*C cSt numbers are here: https://www.bobistheoilguy.com/forum...t&Number=28865
For the non-metric crowd:
40*C is 104*F
100*C is 212*F
40*C is 104*F
100*C is 212*F
40*C is 104*F
100*C is 212*F
40*C is 104*F
100*C is 212*F
Just to make sure i understand.. Royal purple 10w40 would fall within the spec mentioned for morel 5315's and is safe to use? From what i am seeing 20w50 appears to be over the spec and would not be safe to use? Just trying to make sure i understand the numbers since i run the 5315's. Thanks guys! Cool info to know!
Correct on the 20W50 Can't use.
