e85 timing table.
![](https://cimg1.ibsrv.net/gimg/ls1tech.com-vbulletin/2000x1493/image_46f6c580177f920461082d04fbc2d429ccb09e10.jpg)
You don't really need to buy a 4 port. Just replumb your 3 port like the pic above. As far as going down to zero, not sure why you'd need that. Anyway, plumbed this way I cracked my 22 psi boost cut the first couple times until I got the DC figured out. If you decide to replumb, start low and work your way up. Be sure to drill a relief hole in the line going to the done (.030 or so) so pressure doesn't get trapped in the dome.
![](https://cimg3.ibsrv.net/gimg/ls1tech.com-vbulletin/2000x1493/image_3cbbfaebca379d517b0f0aee73425ca3a0cd0898.jpg)
